20 Most Recent
Canon EOS 450D Digital Camera Questions & Answers
Reset factory settings
There's a setting in the menu selection that usually reads "Reset to Factory Settings" or something similar. You can find a PDF manual on Canon's website.
Water damage
If the problem is water in your camera a good way to remove it is to place the camera into a pack of rice. The rice will absorb the water.
Not compatible with acer laptop windows 8.1
The statement is not complete, because you forgot to say what is not compatible.
When you think the Canon EOS 450D is not you are wrong.
For most operating systems you can download the software needed to connect the Canon cameras and acces their memory.
You don't need a driver for Windows 8 just install Zoom browser
Search Results
Auto Focus won't work
Another cause of auto focus failure is the circuit connecting the moving parts inside the lens. These "Flexi circuits" move with the lens components and wear out after a while. They are cheap enough to find on ebay and easy to replace.
Canon 450d lcd will not turn on at all, viewfinder says busy, and camera will not take pictures
In menu option C.Fn-12 you can choose to switch the display off (or on) when you switch on the camera. The display stays off even if you switch of and on the camera.
Press the button <DISP> and switch off the camera, while the settings for recording are on the screen. After you switch on the camera, the LCD screen will be switched on again.
Please refer toy your english manual, I had to translate, because I don't have the English version.
Error code 001 with canon 450d
Seems a lot of people are having the same problem. Take the lens off the camera and clean the little gold contacts (metal squares) on both the lens and the body with isopropyl alcohol or pre-moistened len wipes.
