20 Most Recent
Nikon COOLPIX S610 Digital Camera Questions & Answers
How do I delete all my pictures on my Nikon Coolpix s6100
There is a menu with allowed you to delete, one, selected or all pictures. Or if you really did backup all pictures, you also could go into the menu for a full format, like you do with a new card. It is a good idea, to sometimes format a memory card, because it will free the card form bad files or clusters.
From the manual, (still online):
Nikon coolpixs6100
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Accidenty erased my sims card
RECUVA Recuva (pronounced "recover") is a freeware Windows utility to restore files that have been accidentally deleted from your computer. This includes files emptied from the Recycle bin as well as images and other files that have been deleted by user error from digital camera memory cards or MP3 players. It will even bring back files that have been deleted from your iPod, or by bugs, crashes and viruses!
- Put the memory card into an USB card reader and plug it into the USB port in your computer, then run the Recuva program.
- Simple to use interface - just click 'Scan' and choose the files you want to recover
- Easy to use filter for results based on file name/type
- Simple Windows like interface with List and Tree view
- Can be run from a USB thumb drive
- Restores all types of files, office documents, images, video, music, email, anything.
- Supports FAT12, FAT16, FAT32, exFAT, NTFS, NTFS5 , NTFS + EFS file systems
- Restores files from removable media (SmartMedia, Secure Digital, MemoryStick, Digital cameras, Floppy disks, Jazz Disks, Sony Memory Sticks, Compact Flash cards, Smart Media Cards, Secure Digital Cards, etc.)
- Restores files from external ZIP drives, Firewire and USB Hard drives
- It's fast, tiny and takes seconds to run!
Go to these WEB sites to down Recuva
http://download.cnet.com/Recuva/3000-2242_4-10753287.html www.filehippo.com/download_recuva
This pictures are not clear whats wrong with the camara
Please select the appropriate shooting mode depending on the light(day night, interior or outside), select the highest resolution, remove all additional features if they were set to ON MODE. If confused with settings RESET the camera to factory settings. it should work properly.
Can I get print of user mamual of nikon s6100 cool
You can download a printable manual at http://support.nikonusa.com/app/answers/detail/a_id/17246/ and print it yourself or take the file to an office-supply store or printshop and have them print and bind it for you.
Currently Nikon does not list the S6100 printed manual for sale.
LI WANT TO DOWNLOAD FREE
Having gone over a month without a response to my query, I assume my suggestion to use a card reader solved the problem.
Camera is not switching on
I have an S610 that would sometimes not turn on or randomly turn off. I bought a replacement battery to see if that was the problem but no change. I noticed that if I firmly pressed the battery compartment lid the camera would operate fine, but wiggling the lid would make the camera turn off. I discovered there is a small lever inside the battery compartment that the lid depresses. So my solution was to attach something to the small plastic tab on the lid to help it depress the lever.
My nikon coolpix S610 when
Sounds as if you need to replace you battery. See: http://www.nikon-coolpix-replacement-battery.com/coolpix-s610.htm
Where can I load down
You can download the instruction manual in PDF format by clicking this
link.
Adobe PDF Reader is required to view this manual.
Download Adobe ReaderHope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using
FixYa.
