20 Most Recent
Panasonic DMC-FX37 Digital Camera Questions & Answers
Language change from japanese to english
Slide the [REC]/[PLAYBACK] switch to the REC position (camera icon). Set the mode dial to AUTO (green camera). Press MENU/SET to display the menu. Select LANGUAGE (head with speech bubble). Pick your language from there.
1/27/2021 4:14:24 PM •
Panasonic...
Answered
on Jan 27, 2021
Download software
You don't need a driver or any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo management program such as Picasa (
http://picasa.google.com).
11/30/2013 9:00:40 PM •
Panasonic...
Answered
on Nov 30, 2013
System Error (Focus)
The systems control board has detected a problem with the auto focus lens, the focus is controlled by a tiny motor that has jammed or there is a mechanical issue with the camera lens. It will require a technician that is highly skilled to deal with the situation, but the repair cost would probably not be justified.
10/10/2012 8:23:04 PM •
Panasonic...
Answered
on Oct 10, 2012
How to change language to
Turn the camera on. Slide the REC/PLAYBACK selector to record (the camera icon). Press the MENU/SET button. Press cursor-left, use cursor-up/down to select the wrench icon, and press cursor-right. Use cursor-up/down to select the talking head icon and press cursor-right. Choose the desired language and press MENU/SET.
9/14/2011 6:21:15 PM •
Panasonic...
Answered
on Sep 14, 2011
How will i change my
Slide the [REC]/[PLAYBACK] selector to the recording mode (camera icon). Set the mode dial to the camera icon. Press [MENU/SET] to display the menu. Press cursor-left, use cursor-up/down to select the wrench icon, then press cursor-right. Select the head-with-speech-bubble icon.
6/28/2011 5:16:29 PM •
Panasonic...
Answered
on Jun 28, 2011
