20 Most Recent HP Hewlett Packard Pavilion Slimline S3100N PC Desktop Questions & Answers
2answers
Is there a free software that i can get to run hardware test on my system i took this hp slimline to the repair shop and they told me that they ran Eurosoft pc check,pc Doctor and HP vision Diagnostic
when loading an os you have to completely remove the existing os or there will be compatibility or nothing will change you can try another repair shop but if the shop was pulling a fast one , you would be paying for a whole lot of items and not just for the test if you can get messages on the screen then go to control panel , personalization and display and see if the color , contrast and pixel settings can be adjusted to fix the problem
4/18/2017 9:03:27 PM • HP Hewlett... • Answered on Apr 18, 2017
Why error 0xe0ef000e when I try to reboot?
Recovery DVDs show error 0xe0ef000e this article covers your particular computer please click the link read the article and do as it states. There is also a link on the page to let you create new restore disks. Please give me a good rating if this helps you.
2/24/2015 5:10:29 AM • HP Hewlett... • Answered on Feb 24, 2015
Hp desktop alarming when turned on
Open the lid. Blow (or vacuum) dust away from CPU heat sink. Take out RAM clean the edges with thick cloth. Put back and try again.
8/5/2014 4:18:16 AM • HP Hewlett... • Answered on Aug 05, 2014
How to make my pc faster
Try getting more internet connection or get a external hardrive
7/22/2014 4:47:33 AM • HP Hewlett... • Answered on Jul 22, 2014
I have a HP Pavilion slimline PC purchased in
Try a different monitor. If that works, your old monitor died and you need a new (or used) one.
5/18/2014 5:36:41 PM • HP Hewlett... • Answered on May 18, 2014
Plug and play not working
Uninstall and reinstall the printer software
5/10/2014 3:56:55 PM • HP Hewlett... • Answered on May 10, 2014
How do I recover data from my failing hp pavilion 7935?
remove hard disk from pc and check your hard disk on other PC and take your all data
5/5/2014 9:50:29 AM • HP Hewlett... • Answered on May 05, 2014
Why can't I get my HP s3100n to run USB 2.0?
I was window shopping at Rite Aide and I saw these adapters that you plug into your USB ports and their out puts were 2.0 and others I think it was 12.00 USD
2/6/2014 11:24:04 PM • HP Hewlett... • Answered on Feb 06, 2014
Search.dll is missing
I don't understand your problem, are you referring to Google Chrome browser not opening or can you not get to the Google Website in your browser?
12/23/2013 5:34:21 PM • HP Hewlett... • Answered on Dec 23, 2013
How do I remove password from vista
If Windows notifies you of lassa.exe errors, the cause may be the result of damaged or corrupted registry entries. In most cases, it helps to check the Windows registry for lassa.exe errors! If this does not fix lassa.exe errors, its recommend uninstalling the program using the Control Panel and then running a scan of the Windows registry again.
12/16/2013 12:28:38 PM • HP Hewlett... • Answered on Dec 16, 2013
Computer will not turn off
Which operating system >??? Learning how to use all of the settings and what they mean can help extend the life and speed of a computer. The sleep, hibernate and shutdown settings can help save energy when your computer is not in use. These modes are used when you are away from the computer for an extended period of time. The sleep mode will store any open information on the hard drive while the computer switches to a lower power level, but it allows you to turn the computer on and resume work where you left off. Changing these settings in your computer is easy. Click on the computer's start button. Find the Control Panel option and select it with your mouse. Select Power Options. You will see several options. There should be an option that is already highlighted or selected. This is the current setting on your computer. Click on Change Plan Settings. Your current settings will be displayed. Click on Change Advanced Power Settings. Choose settings. Click on the plus signs in the new dialog box. This will display any options that are available. You will be able to change your sleep, hibernate, and shutdown settings. For instance, you can choose to have your computer hibernate at a certain time, or even wake up at a certain time. If you have a laptop, it will also give you the option to set these while plugged in, or if on battery mode. Click on the Restore Plan Defaults button if you want to reset all changes back to the default setting for your computer. Click the "OK" button when you are done selecting your settings. Select the Control Panel box that still shows your basic power settings. Click on the "Save Changes" button. Exit the Control Panel. Your settings are now saved and are in effect.
11/13/2013 10:43:15 PM • HP Hewlett... • Answered on Nov 13, 2013
How do you know if you needa new battery?
The only battery there is in a desktop PC is the bios battery. If you mean that, then you know it's time to change it when you get 'bio setup error' messages when you turn on the machine.
9/29/2013 9:31:21 PM • HP Hewlett... • Answered on Sep 29, 2013
No picture
Check your monitor if that's not it check your graghic card inside your tower, also if cable internet check wire from modem to tower.
7/11/2013 4:16:53 AM • HP Hewlett... • Answered on Jul 11, 2013
Constant dinging sound
Not my area of expertise, but I found this you may be interested in,http://community.skype.com/t5/Windows-desktop-client/Skype-can-t-connect/td-p/219714Regards,joecoolvette
5/6/2013 8:48:46 PM • HP Hewlett... • Answered on May 06, 2013
Remove quick links on my computer screen
Right click on icons select delete
4/18/2013 9:57:47 PM • HP Hewlett... • Answered on Apr 18, 2013
My hp pavilin slimline wont download anything off of the the internet
Your internet setting are probably set to not download any content. Look into those and change them.
1/24/2013 3:02:59 AM • HP Hewlett... • Answered on Jan 24, 2013
2answers
My pc turns on but windows does not open
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact. Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
1/18/2013 10:18:44 AM • HP Hewlett... • Answered on Jan 18, 2013
Pc does not boot up
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing. The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives Test all power and data leads that attach to your hard drive IDE,SATA the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error Hope this helps.
1/8/2013 7:06:43 AM • HP Hewlett... • Answered on Jan 08, 2013
HP Hewlett Packard Pavilion Slimline S3100N PC Desktop Logo
Popular Tags
100 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
pc turns but windows not open
  • Computers & Internet
