20 Most Recent
IBM Lenovo ThinkPad T60 Questions & Answers
Bios password lenovo T60
there are 2 ways to attempt it. 1/ you need the diagram of your mother board as it involves changing a jumper setting on the board to clear the pass. 2/there is a small round battery inside ( could be under a cover under the laptop ) unplug that battery for a while to clear the cmos. hope this helps
Laptop
What are you doing when it freezes?
When you touch the surface of the laptop is it very hot?
Audio Drivers
Download the driver for your card from the website and install it on your laptop. After doing so, test and adjust the card settings.
Windows won't start
re-install the operating system or restore from a set of back up discs you previously made from the laptop.
I am unable to connect to a wireless network on my ibm thinkpad T60 pc
First is there a security code to connect to your wireless access point? This is YOUR home wireless? Is your wireless adapter enabled, and working properly on the laptop? Reboot the wireless access point by removing th AC plug and wait 30 seconds,plug in, wait for the device to self-test. Cold-start your laptop, unplug. remove battery, plug in, reboot. If that fails go to IBM/ Lonovo website and update driver for wireless adapter.And all other deivers as needed.
Lenovo t60 do not turn on
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
Touchpad cursor freezes frequently
This sounds like a ram memory issue, sub out the ram stick one at a time, no change, take out the second piece and replace the first, if the problem goes away it is the ram stick in your hand that needs to be replaced.
