20 Most Recent
Toshiba TECRA M9 Notebook Questions & Answers
I have a toshiba tecra
also found in another toshiba model. but i think it will be a fault in circuit board, after test i will inform u.
Built in HDD ERROR insert system disk
Check the hard drive has not come loose. If it is properly connected then you need a new hard drive and Operating System Re-install. I hope you have a backup of all your data.
How to remove password on toshiba tecra
Lost Windows password:
- Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode.
- Login as other user (if other user is available) and manage users. Must be an administrator.
- Reformat computer.
- Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
Toshiba tecra m9 pci express error
PCI is a slot/interface at the rear of a lot of standalone pc's,you dont have them on newer pc/laptops,perhaps you just dont have the hardware
When I turn my Toshiba
Try hooking it up to an external monitor (or LCD monitor) and see if the same thing happens (first attach a monitor then do a cold start). My suspicion (from the a's you described) is that the motherboard is bad - I call it garbage video. Toshiba dealers will probably charge too much for these replacements. If you're a DIYer or you know a reasonable shop that knows laptops, then eBay would be a good source for replacement boards.
Can I connect 3 external
You can. You need to buy a VGA Distribution Amplifier that will allow you to connect multiple compatible monitors or projectors for simultaneous viewing.
Good Day.
