20 Most Recent Philips BDP7200/37 Blu-Ray Player Questions & Answers
2answers
Cant play 2012 on my
try other disc.if other disc working fine. some disc no play then there is problem lens assy.
4/7/2020 6:43:55 AM • Philips... • Answered on Apr 07, 2020
2answers
Player will not play blue ray discs
I'm having the same issues.....Anybody?
3/24/2020 3:06:19 AM • Philips... • Answered on Mar 24, 2020
2answers
Won't play because of region code
works on the BDP 2700 - turn on player without disc. push home button(looks like a house) on remote. enter 1389310 using remote. wait 10 sec then turn off at front of player. wait 10 sec then turn on at front of player.I believe the 7200 is not able to be unlocked for region free play though
1/19/2020 6:18:28 AM • Philips... • Answered on Jan 19, 2020
0answers
Philips bdp7200 univeral remote code
go to Radio Schack or best buy. or another electronic stores.or go .http://www.hifi-remote.com/ofa/God bless you
10/16/2012 1:29:03 PM • Philips... • Answered on Oct 16, 2012
Tryed to down load netflix and is stuck on a please wait screen
use accelerator download for download program, films.etc2) you must shure that you have a good connection internet +speed3) must be enough memory4) enought space disk5) clean all cookies+cachee , from your brower web, +disk6) Try again.God bless you
7/14/2012 1:37:40 PM • Philips... • Answered on Jul 14, 2012
My dvd player read cd properly but does not read dvd
The laser pickup is failing and is approaching end of life, the CD disc requires less speed and precision than the DVD applications, far cheaper to replace with a new player.
5/14/2012 2:13:14 PM • Philips... • Answered on May 14, 2012
Type your problem for a solution...
Either its loading motor or loading belt is faulty.
5/10/2012 11:32:41 AM • Philips... • Answered on May 10, 2012
0answers
I need a Manual for
8/3/2011 1:57:52 AM • Philips... • Answered on Aug 03, 2011
0answers
How do i make my philips BDP2700 region free?
1. Make sure there is no disc in the tray when you switch on.
2. Press "home" key on remote control.
3. Enter number "1389310".
4. Switch off. Wait a few seconds and then switch on...now region free.
12/16/2010 6:15:47 AM • Philips... • Answered on Dec 16, 2010
Need default password for phillips dvd
default passwords are usually 0000/1111/1234 etc. try looking in the users manual for the starting code.
7/23/2009 3:12:39 AM • Philips... • Answered on Jul 23, 2009
Wont play dvd says enter pasword
Found this information on the Phillips USA website. http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=DVD_HOME_THEATER_CA&sct=DVD_PLAYERS_SU&session=200906 This information is in the owners manual on page (45). I hope this information helps you with your problem You need to enter your six-digit
password to play a prohibited disc or if
prompted for a password. The same
default password is used for both
Parental and Disc Lock.
A In ‘Preference Page’, press 􀁓 􀁔 to select
{ Password }, then press 􀁘 to select
{ Change }.
B Press OK and the menu appears on the
TV screen.
Old Password
New Password
Confirm PWD
OK
C Use the alphanumeric keypad 0-9 to
enter the six-digit password.
􀃎 When doing this for the fi rst time,
enter the default password ‘136900’.
􀁺 If you forget your old six-digit password,
D Enter the new six-digit password.
E Enter the new six-digit password a
second time to confi rm.
􀃎 The new six-digit password will now
take effect.
F Press OK to confi rm.
6/2/2009 2:55:15 AM • Philips... • Answered on Jun 02, 2009
Philips LCD 42PFL3603D/F7 won't stay on until I've held the power button in a few times. The display comes on, then I hear a click and it shuts off. After a few cycles of this it stays on
Remove the cover on the back of the tv. Look for swollen or leaking capacitors. They kinda look like batteries. If they are bulging or leaking then that is your problem. You will have to de-solder the old ones off. Then solder the new capacitors onto the circuit board. Capacitors will cost about 20 dollars and installing them isn't that hard to do. It will fix your tv 99% of the time. So it is worth a try!
2/21/2024 9:36:48 AM • Philips... • Answered on Feb 21, 2024
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM • Philips... • Answered on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay https://www.ebay.ca > ... > Remote Controls Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ... $67.67 · ‎In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay https://www.ebay.ca > ... > Remote Controls PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost. US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com https://www.replacementremotes.com > philips > buy-... PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM • Philips... • Answered on Dec 05, 2023
Philips BDP7200/37 Blu-Ray Player Logo
23 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
type problem solution
  • Televison & Video
