20 Most Recent
Memorex MLT3221 32 in. LCD TV Questions & Answers
No picture on Memorex MLTD3222 flat panel LCD.
I recently got this tv from somone because of this exact problem. I have found a solution that works for mine. You can check to see if it works for you also. What I did was take of the back cover. 3 screws (1 big one in the center and 2 little ones below it). Next look at the power board. If plugged in and turned on the red light on the power board should be lit up. If so your power board is fine. Next find the component that has 4 switches. I manually turned these on and turned the tv on and it worked! Has been working ever since!
My volume want get lounder
Check whether the audio is
half muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Lnt466 samsung tv will not turn on
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
It shows no picture but i can hear the words
Check if you got a picture somewere in the dark screen.
If you got anything moving but very dark, then you need a new invertor.
If its totally dead you need a new card inside the tv.
Its a job for a pro.
No picture
Check for bursted electrolytic capacitors at its main power supply regulator board. It will be best to replace the board as card basis, rather than making any 'surgery' to it. If
you wish to get more details, check this link.
http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic
/Timeslide, can be selected by the drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name / model
number / IC used, in the search box at the top right of the display window.
