20 Most Recent
Sceptre X42BV 42 in. LCD TV Questions & Answers
Both HDMI ports are bad due to lightening strikes.
The main tv Tuner signal board have problems and all those HDMI insert ports are shorted dead,those HDMI insert ports are put on by wave soldering machine and fused by iron core solders joints to the main tv Tuner board itself.These HDMI insert ports are not replaceable by hand soldering equipments or can buy those HDMI insert ports individually anyway.Tv still work wright?Yes? Why don't u just skips the used of those HDMI insert ports all together and tries used those RCA component cable connections like AV1 and AV2 on the tv.Or u must have some mechanicals skills and like take things aparts and putting back together again?Yes?Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv main Tuner signal board for the replacement to able to used those HDMI insert ports again.I have the same problems with my Samasung 46" all my HDMI insert ports are dead too,but the tv still functions.That what i did used RCA cable components connections for my cable box and blu Ray player.
Volume control
Sceptre X42BV LCD HDTV
The
To start the conversation, i would like you to ON the TV and take the remote to a different room. Then observe and see, if there is an issue with the volume. If not, then this is a case of faulty remote. I have seen few times when a faulty remote could send irregular signals and cause to volume to react in an unusual behavior. If the problem remains the same, then this is an internal failure and needs repair. You need to open the TV and check different components. In most cases, it is often faulty main board, however we cannot jump to any conclusion without testing the components. If the remote is not at fault, either you could call a tech or if you have prior experience of working on these sets, have electrical equipment and would be able to carry the repair, revert and i would be able to provide few more details and could possible provide you with a link to buy service manual which would be helpful.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
My TV randomly starts flipping channels and the
Either the remote batteries are dying causing you this problem Or the IR (infar red sensor) is faulty and thinks you are changing the channel. It is controlled by capacitors and resistors and will need to be tested with an oscilloscope and a VOM (volt/ohmmeter) to determine if that's exactly what is wrong. A service manual will also be needed for specs
When i hook up the hdmi cable into hdmi 1,2, 3 or
Make sure you have the right cable version there is hdmi 1.2,1.3 and so on if you got a 1.1 get a 1.2 for batter capatablilty also check the device the supposed to produce the sound it may be having a issue as well.
before ruling out the tv as bad rule out the devices connect and the cable do not shoot the help please do rate. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
I have a DVD that is stuck in the player, the eject button does not release it. Help!
You'll have to take the cover off. This only consists of a few screws to remove, and lifting off the cover. When you have the cover off, try turning any white gears (carefully) to open the drawer. Some tray mechanisms have bad design. They refuse to open after a few months. This is in the design of the plastic parts and mechanisms of the cd drawer. Flawed design.
12/17/2022 2:56:15 AM •
Sceptre...
Answered
on Dec 17, 2022
How to connect laptop to Sceptre TV
HDMI Connection
- Connect one end of the HDMI cable to the laptop VGA port.
- Connect the other end of the HDMI cable to one of the HDMI connections on the rear of the TV.
- Connect a separate audio cable between the headphone or speaker output on the laptop and the audio in connector on the TV.
9/13/2022 3:39:27 PM •
Sceptre...
Answered
on Sep 13, 2022
Sceptre hktv83ac black screen no image
A lot of people miss understand how the backlight circuit in the power supply works, you will get voltage testing to ground as its the B- side that's switched, the chassis ground and backlight B- are not connected. If you tested each LED strip and they're all good there has to be something else going on other than the typical backlight issue we see on so many LED sets.. I'm not an authorized service center for this brand TV so I don't have a service manual, if this set has separate power board and main test the bl_on pin on the power supply, you should have around 3.5 volts there, that's what tells the back light section of the power supply to turn on.If you don't then it's a bad main board
8/12/2021 7:26:33 PM •
Sceptre...
Answered
on Aug 12, 2021
Trying to program direct tv remote to sceptre tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
7/25/2021 2:32:50 PM •
Sceptre...
Answered
on Jul 25, 2021
