20 Most Recent ViewSonic N1930W 19 in. LCD TV Questions & Answers
How do I unlock the the input menu? I forgot the password and it doesn't let me use the HDMI connection option.
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock to many popular brand TVs are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
4/28/2016 4:30:48 AM • ViewSonic N1930W... • Answered on Apr 28, 2016
How do i turn off the power lock on my view sonic n1930
It does work with signal like this or you change your main board
7/20/2015 2:02:01 AM • ViewSonic N1930W... • Answered on Jul 20, 2015
I have a n1930w-2m tv and the screen is really dark, I've tried adjusting the picture settings in the menu but they don't help, anyone have any ideas?
Backlighting bulbs are out. They may need replacing, but check to see if they are getting power first.
12/3/2014 10:37:33 PM • ViewSonic N1930W... • Answered on Dec 03, 2014
How to unlock channels on viewsonic monitor
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter". http://electronicshelponline.blogspot.com/ Unlock procedure is too much to type in here, and is not practical.
7/10/2014 9:57:56 AM • ViewSonic N1930W... • Answered on Jul 10, 2014
0answers
Power locked viewsonic n1930w
On the tv itself hold down CHANNEL button and hold the MENU button then press the POWER button, You will get into the service menu. from here I went in to the CARNIVAL menus and changed the PW setting then backed out... Power button worked. Then I went back in and played with everything else... but in the end left everything the way it was in the end. I suggest you do the same. Good luck.
8/24/2013 2:23:45 AM • ViewSonic N1930W... • Answered on Aug 24, 2013
Tv powers on, see three birds in color then flickers and fades to white
The problem must be with its main digital processor board. It will be best to make it confirm. Contact any service technician. Try this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
5/20/2013 5:19:10 AM • ViewSonic N1930W... • Answered on May 20, 2013
Viewsonic N1930w
Check its tuner. If tuner is faulty, this kind of fault can occur. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. http://electronicshelponline.blogspot.com/
5/11/2013 3:22:56 PM • ViewSonic N1930W... • Answered on May 11, 2013
Need ViewSonic N1930W repair manual
Here you go http://www.manualowl.com/p/ViewSonic/N1930W/Manual/20267
9/26/2011 3:24:03 PM • ViewSonic N1930W... • Answered on Sep 26, 2011
2answers
Viewsonic N1930W input menu missing
According to this image, the input you are looking for is marked 'G'.
You would then use the Input button on your remote control to select that option. The OSD does not support selection of the input.
10/28/2010 1:10:21 AM • ViewSonic N1930W... • Answered on Oct 28, 2010
VGA hookup to my Toshiba Satellite
Set the TV input to PC (that's ViewSonic's term for the VGA port).
Setting the computer to output to the PC may depend on your OS (XP, Vista). Reboot the computer after connecting the monitor and see if new hardware is found. Reboot again if you have a flickering screen. In Vista, right clicking on the desktop brings up various video and desktop options. Choose Screen Resolution and look for the multiple monitors line. Click Apply and OK after setting your desired output. In the Screen Resolution window you should see two monitor boxes (labeled 1 and 2) if the computer sees the monitor.
If the second monitor is not showing up (no new hardware found), check your BIOS and device drivers to see if you need to enable or update the drivers for the VGA port. Check your manual for the BIOS (often it is click F1 or F2 before the OS loads; it's often tricky timing and I have to try repeatedly). Device manager will have a red x if the port is disabled; the exclamation point (yellow triangle) indicates driver issues.
I realize this is nearly a year after you posted your questions but I hope it will help the next person searching for answers on this TV.
4/13/2010 4:00:51 AM • ViewSonic N1930W... • Answered on Apr 13, 2010
I will be watchings my viewsonic n1930w and the
Sounds like your power supply electrolytic caps are going bad.....or you have a small board break in one of the circuit connections that doesnt break until the unit warms up.
First, you can use a can of cold blast to check for that heat break. You need to be able to shoot the cold blast at small areas of the board to see when the unit comes back on..indicating the break was shrunk closed by the coldness of the spray. If the unit fails to come on....you can remove the power supply and replace the caps as a group *(recommended since when one is bad...the others are sure to follow)
Good luck and be careful. These power supplys produce high voltage for the backlight and have `110V AC running into them. Be very sure you are adept at handling live circuits or find someone with electronics skills who will work on the cheap!
3/11/2010 8:44:53 PM • ViewSonic N1930W... • Answered on Mar 11, 2010
I cannot find hdtv channels on my viewsonic n1930w
Are you trying to get the HD signal from the roof antenna or from cable? when you set the tuner to scan for channels make sure it is set for 'CABLE' if you are on cable, or 'AIR' if using roof antenna.
10/31/2009 2:15:30 AM • ViewSonic N1930W... • Answered on Oct 31, 2009
White screen, no picture.
Base from my experience this problem is 75%(BAD LCD) needs to be replaced with new LCD. The rest of 25% is cable connection loose.
Roan
8/4/2009 12:12:08 AM • ViewSonic N1930W... • Answered on Aug 04, 2009
ViewSonic N1930W 19 in. LCD TV Logo
26 questions posted
Top ViewSonic Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • ViewSonic Televison & Video
Most Popular Question
need viewsonic n1930w repair manual
  • Televison & Video
