20 Most Recent
Philips 42PFL3603D/27 42 in. LCD TV Questions & Answers
I have a 42PFL3603D/F7, and the tv doesnt turn on right away, it takes about 8 times for it to stay on. Any suggestions
Power supply is in need of repair. Pull out the power supply. You will find transformer (has blue tape). The location of this transformer is T701. Underside of this transformer, pin # EL41 is in need of a resolder.With a small screwdriver, scratch an area next and around this pin. With a hot soldering iron and solder...resolder this pin. Your TV will be fine. There are no capacitors to replace. This is one of the best power supplies built for Philips TVs. Thanks for asking, Matt of Martins TV.
10/11/2015 5:13:17 AM •
Philips...
Answered
on Oct 11, 2015
My Phillips 42FPL3603D/27 clicks constantly when
It sounds that the main power regulator board has the fault. Your TV need a through check up. It will be best to contact any service technician, or to authorized service centre for Philips. If you're sound in electronics, and wish to get more details,
check this link.
http://electronicshelponline.blogspot.com/ Selecting the view option, either to
Mosaic
/ Time slide, can be selected by the
drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window.
10/10/2015 6:35:11 AM •
Philips...
Answered
on Oct 10, 2015
Error message on my LCD
download proper firmware for your model from philips website and complete firmware upgrade. That should solve your problem.
3/25/2015 8:26:27 AM •
Philips...
Answered
on Mar 25, 2015
Phillips HDTV 42PFL3603D/F7 screen is grey (after phillips power-up logo shows) when plugged in, will not power off, remote led blinks when used, but no change.
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts.
http://electronicshelponline.blogspot.com/ Check the site in '
Mosaic' view. It will make search easy.
1/7/2014 3:23:01 PM •
Philips...
Answered
on Jan 07, 2014
