20 Most Recent
Philips 52PFL7403D 52 in. LCD HDTV Questions & Answers
Need to find out a
I have a Philips 47PFL3603D/F7 with the same problem. It was the IR
sensor board causing the problem. You can search online to find the
board, which almost everyone will most likely not have in stock, and
cant be ordered. The part you need is this: 313926859181 IR Remote
Sensor.
Models it will fit are as follows: Substitute Parts 313926859182
Known Models
MAGNAVOX 42MF438B/27
MAGNAVOX 42MF438B/F7
MAGNAVOX 52MF438B/27
MAGNAVOX 52MF438B/F7
PHILIPS 32PFL3403D/85
PHILIPS 42PFL3403D/27
PHILIPS 42PFL3403D/F7
PHILIPS 42PFL3603D/27
PHILIPS 42PFL3603D/F7
PHILIPS 47PFL3603D/27
PHILIPS 47PFL3603D/F7
PHILIPS 52PFL3603D/27
PHILIPS 52PFL3603D/F7
If you can find the board, great! A replacement board costs about
$12.00. If you can't... we'll there is something you can try ; )
Either way, if you know it's the board, what's the harm in trying?
Remove the back from the TV. You can actually leave it on your stand to
do this if you can spin it around to gain access to the back of it. Be
sure to unplug everything first!!!
Looking at the back of the tv, the board will be located in the lower
left side by the speaker. It will have 2 cables attached to it. Remove
them, and take out the screw or two that holds it in place. There will
be a plastic tab that keeps it in place also.
Take your fingernail and bend the tab back, and the board should come
free. After that you should be holding the board in your hands. The side
of the board with the connectors on it is the side you want to
manipulate. There will be a tiny surface mounted capacitor beside one of
the wire connection sockets. Take a utility knife and scrape it off/
you could use a soldering iron but it should come off very easy with a
knife.
Plug it back in, and give it a try! If it works... great! If not, find a replacement board, and try that.
Hope it helps someone!!!!
2/28/2015 3:42:38 AM •
Philips...
Answered
on Feb 28, 2015
Where can i find a ir sensor for my Philips
There are plenty of places you can look. Shopjimmy.com. Tiger parts direct. Encompass parts are just a few. Just google the part# and some part suppliers will pop up.
9/29/2013 4:52:35 PM •
Philips...
Answered
on Sep 29, 2013
Sound on but no picture
Is the screen pitch black or a blue/grayish ? Dim the lights in the room, and shine a bright flash light on the panel. Turn on the set, if you see a faint picture, you have a backlight issue
12/13/2012 5:18:00 PM •
Philips...
Answered
on Dec 13, 2012
Screen is black after the initial white screen
I believe a firmware update can fix this issue. However to be sure I would need your entire model number, including the numbers after the slash. You can put that entire model number into Philips support website, http://www.usa.philips.com/#/headernav/consumer/
Once you get to your TV's support page, you can look on the right hand side and find the firmware information. First I suggest you read the Read Me file to familiarize yourself with the update process and what issues it fixes. Then you can download the firmware to your computer so you can upload it to a USB drive to perform the update.
Hope that helps!
8/23/2011 10:36:59 PM •
Philips...
Answered
on Aug 23, 2011
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM •
Philips...
Answered
on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay
https://www.ebay.ca > ... > Remote Controls
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ...
$67.67 · In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay
PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost.
US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com
https://www.replacementremotes.com > philips > buy-...
PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM •
Philips...
Answered
on Dec 05, 2023
My rmt-d197a remote, i am trying to pair with my Philips t v
In order to pair your RMT-D197A remote to your Philips TV, follow these steps: 1. Power on the TV with the remote. 2. Press and hold the Setup button on the remote until the red LED light blinks twice. 3. Input the four-digit code that corresponds to your brand of TV on the remote. This should be found on the enclosed code list. 4. Release the Setup button. If the code is correct, the red LED light will blink twice. 5. Aim the remote at the TV and press the Volume Up button. If the TV responds, the remote is paired correctly.
10/31/2023 4:44:00 PM •
Philips...
Answered
on Oct 31, 2023
