20 Most Recent Vizio VU32L 32 in. HDTV LCD Questions & Answers
Need a code that works with the Verizon FIOS DVR
Try 0000000000
2/21/2015 6:10:14 AM • Vizio VU32L 32... • Answered on Feb 21, 2015
Rf cable connection inside tv can i take back off
Yes. You can.
9/23/2013 5:36:17 PM • Vizio VU32L 32... • Answered on Sep 23, 2013
2answers
Wont power up?
Any light on the front at all? First place to look will be the power suppply module, you need to check the main AC fuse and DC filter caps (bad caps with domed tops). It can also be due to the main board or shorted out inverter boards.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on: Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Parts: http://interliquidparts.com/ Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps. Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
6/21/2011 3:48:08 PM • Vizio VU32L 32... • Answered on Jun 21, 2011
While connected to to dish network when program
Hello! I hope that this has been resolved, but if not, or if you have questions, here are some steps that you can go through. To get this resolved, you simply want to unplug the receiver from the power source for 10 seconds, then plug it back in, and allow the receiver to acquire the signal, and if needed, the program guide, and you will be good to go.
Becki Barned
DISH Network Customer Service
1/16/2011 4:11:32 AM • Vizio VU32L 32... • Answered on Jan 16, 2011
2answers
How do you change a capacitor in a Vizio hdtv
Its all one unit, ITs part of the PSU, heres a picture and there about $40 bucks. ITs pretty simple to do, just remove all of the back screws and this board will be in plan sight. Then its pretty much un plug and reinstall the PSU.xynx.jpg
Power Board 0500-0507-0530 (WebID: 1243) Recertified
For use with VIZIO TV Model number(s): VU32L HDTV10A, VO32L HDTV10A, VW32L HDTV30A
12/11/2010 11:47:56 PM • Vizio VU32L 32... • Answered on Dec 11, 2010
I can't program my at&t remote control for my
hi! i have here a couple of codes for your VIZIO tv, just try them 1004, 1429, 1433, 1439, hope this helps!!!! goodluck!!!
6/9/2010 11:42:01 AM • Vizio VU32L 32... • Answered on Jun 09, 2010
2answers
I need a diagram on how to hook up my vizio tv to
At the rear or side of the PC there should be either or both of a 15 Pin DIN Plug, HDMI socket. or a Yellow RCA or 4 -7 pin DIN. Now IF these are present then YES you can connect to a TV. Now some TV's have a connector a DB15 MALE, so that the cable from the PC to the TV, is DB15. this plugs in directly, with appropriate DB15 cable. This, however, will ONLY take the VIDEO to the TV, Audio is delivered via the "Audio Out" Jack on PC, and Plugged into the AV Sockets on the TV, with a dual cored coaxial cable, they are Red & White. Some PC's also have a Yellow RCA Connector, OR a 4 -7 Pin DIN Socket, that requires a Special Adapter Cable (That generally came with the unit, and are colored and marked as to output) to use, for Video/Audio Out to TV. This signal is Composite or SVHS Video & Stereo Out. This connects up TO the TV's Composite/SVHS input Jacks and the Red & White Audio IN, RCA Jacks, &/or DIN SVHS socket. Also we have "Component Video" marked "Y" "Pb" & "Pr" these simply go color to color at BOTH ends, this is where the Red, Green, & Blues, colored Ends, of the Wires, goes, remembering that this is ALL only Video. With this method, you still must use the AV, red & White, Audio, Inputs to get the "Sound" into the unit
First you need to know if your PC can output to a TV. Then you need to get the adapter & cables that connect the PC to the TV. Then you need the correct TV drivers installed for your video card. When they are all installed, you need to "Enable" that Monitors, the TV's, Desktop. You need to set either a "Cloned" display or "Spanned, Extended Desktop". Go to "Display Settings" Now ensure the TV/Monitor connected has the correct input/output display settings. Adjust the screens resolution via the resoloution "Slider", it is best to start with, 800x600 32 bit color. or even lower. and once working OK, THEN increase to max resolution, your TV can handle, find out from manual. Once it is all connected up. It should all just work great. Now, from then on, &, to get it to work every-time, the process is. Turn everything OFF. Connect the leads between PC & TV, Turn the TV, ON. Then, startup the PC up. It should "Detect" that it has TWO "Monitors" ie: One Monitor & One TV/Monitor, & you should see your desktop appear after a bit. Now you have screen 1 & screens 2. Now, if you are using "Cloned" mode, then whatever is displayed on the Master monitor, will be displayed on the TV. If you used Spanned, mode, in this mode, however, you will have to."Drag" the Video window, over to the TV, and it is though, you have one "Big Desktop". Now IF using Nvidia or ATI then BOTH of those have thier OWN, Control Panel, this, all then can make it all a lot easier to do it. So I would suggest that this method be used. But if you get stuck, or just want to do it by hand, then the the "By Hand" method is the only way.There is a great program called MultiMon, this allows great control over dual displays, and is well worth installing.
Connecting this up will be easy. What you do is get a yourself a set of the right, for your setup, cables. That uses EITHER one of the formats, of these described, below. You will need, either, a THREE way Cable, or three separate " Coaxial Cored" Cables with RCA PLUGS on them. Colored Yellow, (Video) Red, & White. (Audio) AV. OR If you haveSCART Connection Sockets, it's a big Black Socket at rear of unit(s), you get a SCART Cable.& It's all inside. Now some units, use a standard called Component Video, that uses, a Green, Red, & Blue Plugs. Also we have with the "Component Video" it is marked "Y" "Pb" & "Pr" these simply go color to color at BOTH ends, this is where the Red, Green, & Blues, colored Ends, of the Wires, goes, remembering that this is ALL only Video. With this method, you still must use the AV, red & White, Audio, Inputs to get the "Sound" into the unit, with the Component setup, you will also ,need, Two more Cables, for the AV Audio. these are, Red &White.(So with Component Video there are 5 Cables/Plugs in all). In any event ALL Cables go Color to Color, at each end, plugging into the corresponding Colored RCA Jacks, on either machine, or VCR or TV. Now if you have SCART, then it simply plugs in only one way. It is that simple. So connect up with the leads your set uses, and select the correct "Input" from TV/Remote, it is NOT on a "Channel" it will be on AV, AUX, and Press "Play" on VCR/DVD whatever.... should be all go.
3/21/2010 5:48:50 AM • Vizio VU32L 32... • Answered on Mar 21, 2010
Will not come on like no power
The power ic inverter board is dead.
U need a new one.
8/25/2009 7:52:53 PM • Vizio VU32L 32... • Answered on Aug 25, 2009
Blue under eyes
Hi there! If this a fault that ocurred a while after purchase then I would suggest a repairer. If it has been like this since you purchased it, it may be your decoder or antenna which is not compatible with HDTV. It's like purchasing a Mercedes and driving it with a Toyota engine. The two items have to be compatible. Query with your supplier if you are not sure. Best Wishes and Good Luck, JUS004
8/23/2009 10:06:18 AM • Vizio VU32L 32... • Answered on Aug 23, 2009
My vizio will not turn off either ,has sound but
You need a main board, costs about $200-$300, setup an ebay search to wait for one listed with a broken screen(parts TV) must be same exact model. gd lk
E I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
8/21/2009 7:45:11 AM • Vizio VU32L 32... • Answered on Aug 21, 2009
VIZIO 32 INCH MADE CLICKING NOISE WONT POWER UP
The power supply in the TV has to be checked for supplying current to the circuit of the TV display. It requires high voltage to get it going which might have blown a fuse internally. That will not cost too much but if it is still under warranty then better to ask for a replacement 'cos once it starts giving trouble, repairs may not solve the problem permanently & has a habit of repeating it. My suggestion would be to to repair it & dispose it as soon as possible & get a new one. By the way the reset button could be in the remote which won't be working since the unit is not powering up. There's no problem with the chord. The TV needs repair of its own power distribution inside the TV circuit.................sodeep
8/18/2009 4:53:05 PM • Vizio VU32L 32... • Answered on Aug 18, 2009
Half of screen is green, split down the middle
I never repair Vizio but I am sure this is the cause if this occurs on all video sources; WiI, TV tuner, etc.
LCD panel has 2 flat cables attached to the glass OR the board that attaches to the glass.
remove and reinsert this cable. Just know that if you open the TV you will probably see these cable easily....they will be at the upper middle portion of the back of the TV(inside of course)
There is 1 cable for the left side of the picture and another cable for the right. If the right becomes loose it affect right side of pictur and left cable left side.
7/10/2009 11:55:31 AM • Vizio VU32L 32... • Answered on Jul 10, 2009
Vizio all in one computer VIZIO CA-27 voltage and part number for subwoofer/power supply replacement
The power supply/subwoofer for the VIZIO CA-27 series all-in-one PCs is identified by the part number 715G6960-P02-001-002S or ADTVE1825AC71. The power supply connects to the motherboard via a proprietary dual jack Audio/Power cable. I couldn't find specific voltage details for the subwoofer/power supply in the available resources. For precise information, I recommend checking the user manual or contacting VIZIO customer support directly.
3/9/2024 5:42:30 AM • Vizio Televison... • Answered on Mar 09, 2024
Vizio VU32L 32 in. HDTV LCD Logo
32 questions posted
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Vizio Televison & Video
Most Popular Question
rf cable connection inside tv back off
  • Televison & Video
