20 Most Recent
Mitsubishi LT-52246 52 in. LCD TV Questions & Answers
Blue line on the left side
One of the connectors to the LCD panel is faulty. Need to open the cover, access to the top area where you will find connectors to the LCD panel. Check the connector nearest to the blue line. Carefully remove the connector, check for damage. If all ok, carefully connect it back. Use some binding tape to hold the connector to the panel. Test it before closing it up. Hope this works.
Red on and off light keeps blinking and tv will
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where.If otherwise, the power supply board is dead, do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem....
A 2" shadow line runing
Hi that can be two things. First your LCD screen might be bad the second thing is your T-con board might be bad. The only way to find out is to actually replace the T-con board. If the line goes away that was your problem if it does not then it's your screen. You can find parts for that TV at
www.interliquidparts.com
I have a 3
This is comming from your tuner/decoder and the rectification is repair. Your going to need to have a service guy come out and look at it.
1. Tuner/decoder Fault
Thanks, Hope this information helps please do leave positive feedback and ratings for your free answer today! Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Mitsubishi VCR HS-U580 guide rollers not moving forward all the way. Cassette would not load. Also noticed drum not spinning when powered on
Your Mitsubishi VCR HS-U580 looks to have a problem with the information rollers and drum. Here are some things to check:
Look for something blocking the VCR or cassette compartment that would possibly be stopping the guide rollers.
Check the belt that drives the VCR mechanism. If it is loose or broken, you may also need to substitute it.
Clean the video heads using a head-cleaning cassette to make certain they're not dirty.
See if the drum motor is working. If it is not spinning, there may be an issue with the motor.
If the trouble persists, it's an exact idea to get assistance from a professional technician or contact Mitsubishi's purchaser support for advice.
Be cautious when dealing with electronic devices, and if you are not certain what to do, it's great to get assistance from an expert.
Where could I download a copy of a service manual for mitsubishi hs-u580 vcr?
i think finding a downloadable service manual for your Mitsubishi HS-U580 VCR might take some searching, but here are a few options:
Check the official Mitsubishi website's support section. They might offer downloadable manuals for older models.Many online appliance parts stores like RepairClinic or AppliancePartsPros stock service manuals for various brands and models. Search for your specific VCR model to see if they have it available.Websites like ManualsLib or iFixit sometimes host user-uploaded service manuals. While the availability and quality can vary, it's worth checking. If online options fail, consider purchasing a physical copy of the service manual from online marketplaces like eBay or Amazon.
Remember, some websites might charge a fee for downloading manuals. Always be cautious of suspicious websites and download from reputable sources.
I own a Mitsubishi 1080 1EEE 1394 television. Yesterday, we had a planned power outage in our area. When the power was restored, the only picture I can get is flipping horizontal lines?
Hoping you did not have electric overload that damaged the power supply, try unplugging the set and push the button On until no lights indicate anything. Then wait about an hour so the capacitors would empty themselves further. Next plug it back in and see if this worked. It is never wrong to push the edges a little in finding if the cables that go around the screen have a problem at that point. When one opens the TV (off power and unplugged) these flat cables should be checked for corrosion and right position in connectors. Corrosion is caused by little moist only, combined with the electricity. Then see if capacitors from the power supply, or any at all, have expanded tops. Those are the larger and smaller towers with metal on top that is divided in three parts. New ones alike can then be ordered but replacing requires basic skills. Further examples can be found on YouTube. Capacitors are common to fail early. Those larger ones have dangerous high voltage and can hold their charge for long span of time. it is not uncommon for devices like this to fail after being off.
I have a Mitsubishi TV LT-55154 with no picture it has sound but no picture. The green light is solid.
If your Mitsubishi TV LT-55154 has no picture but has sound and the green light is solid, there are a few potential causes for this issue:
- Faulty backlight: The backlight in your TV is responsible for illuminating the screen. If the backlight is not functioning properly, it can result in a black screen while still producing sound. You can try shining a flashlight on the screen at different angles to check if you can see any faint images. If you can, it indicates a backlight issue. In such cases, the backlight unit may need to be replaced. Contact a professional technician or the manufacturer's support for further assistance.
- Loose or damaged cables: Check that all the cables connecting your TV to external devices (such as cable/satellite boxes, DVD players, or gaming consoles) are securely plugged in. Ensure that there are no loose connections or damaged cables, as this can lead to a loss of video signal.
- Incorrect input/source selection: Make sure that the TV is set to the correct input or source that corresponds to the device you want to watch. Use the TV remote to cycle through the available input options and see if the picture appears on any of them.
- Display settings: It's possible that the display settings on your TV have been inadvertently adjusted or misconfigured. Check the TV's menu options for any settings related to picture or display, such as brightness, contrast, or picture mode. Resetting these settings to their default values might help resolve the issue.
- Hardware malfunction: In some cases, a hardware malfunction within the TV, such as a faulty video processing unit or mainboard, can cause a loss of picture. In such situations, it's recommended to contact a professional technician or the manufacturer's support for further troubleshooting and potential repairs.
Remember to exercise caution when working with electronics, and if you are unsure about any steps or lack the technical expertise, it's best to seek professional assistance to avoid causing further damage to your TV.
