20 Most Recent
Proscan 26LB30QD 26 in. LCD HDTV Questions & Answers
Why does my picture flash on a proscan 42
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Where do I find my link code
Link code for which service provider? See below:
CableVision UR2-CBL-CV04 code: 096
Charter DIGITAL code: 0463
Comcast M1057 code: 0463, 10463
Cox COX code: 0463
Direct TV RC23 code: 10463
Dish Network VIP508 code: 720
Dish Network VIP622 code: 720
Motorola DRC800 code: 0463
One for All URC-6690 code: 0464
Phillips PDVR8 code: 115
Phillips PH5DSS code: 115
Phillips PHDVD5 code: 115
Phillips PMDVR8 code: 115
RCA RCU807 code: 135
Rogers DCT3250 code: 0463
Shaw DCT3416 code: 0463
Sony RM-VL600 code: 8043
TiVo HD code: 0091
TiVo SERIES 3 code: 0091
How do I switch from cable to an antenna
For the Proscan 26LB30QD, first make sure that the input is set to TV. (Use the Input button on the TV (top button on the side) or remote with that function.) Then press Menu (second button from the top on the TV) and use the up/down buttons/arrows to select Setup Menu. Use the left/right arrows to move into the sub-menu. Select the line Tuning Band with the up/down buttons/arrows. Use the left/right arrows to change the signal from Cable to Air. Press Enter (the Input button on the TV) to save the setting. Go back to Setup Menu and find Auto Ch Search to scan for channels. Once you select this line, press Enter and wait for the scan to be completed. Press Menu to exit.
I hope this helps.
Does anyone have the tv code for the Dish remote for this tv?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Why am I not getting any picture or sound when I hook up my ps3 to hdmi ports one and two?
The drivers on those particular ports have been loaded yet. From desktop hit "start" then right click on computer then click on "manage". Nest click on "device Manager" when it opens up look for ports with yellow question marks and right click on them and trouble shoot them. Or,, you may have to go down o the bottom of the page and open up some new ports and drivers.
Col. Dana Gillespie
Click on botton, blue lite comes on and inmediatly turns off
Your diagnostic circuit is detecting a problem somewhere in the set and shutting it down to protect the remaining good circuits. Check the power board for fault it is usually the culprit. Look for capacitors with spewed up tops. They may also be leaking a oily like substance (electrolyte) and when replaced will fix it. If not then your problem could in many places. Look at the power board first and see if the voltages are coming off it if the capacitors are OK.
If not then nothing else on the board can be fixed. You will have to order another. If I can help with anything please feel free to contact me anytime.
Col. Dana Gillespie
Proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
