20 Most Recent Memorex MLTD2622 26 in. LCD TV Questions & Answers
If you have the new Hopper system you should be able to go into the menu settings and look for the remote icon. Once you do this you can tell the receiver what kind of TV you have. It will program itself for you.
Memorex MLTD2622... | Answered on Oct 14, 2014
27.3 pounds manual is on WiseOwl.com
Memorex MLTD2622... | Answered on Oct 21, 2013
Programming procedure is so much to type in here. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2250 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Memorex MLTD2622... | Answered on Apr 14, 2013
D10 is shorted. HER304 in middle of Power supply board near large electrolytic cap. Replace with Radio Shack 276-1144 3A 400PIV Diode. PLEASE BE CAREFUL WITH HIGH VOLTAGE PRESENT ON POWER SUPPLY BOARD. UNPLUG POWER CORD!!! OBSERVE PROPER POLARITY WHEN REPLACING DIODE-LOOK WHERE THE BAND IS.
PS- I fixed this model this morning.
Memorex MLTD2622... | Answered on Nov 16, 2012
Check its main power regulator board for fault. Check and replace it as card basis.
Memorex MLTD2622... | Answered on Jul 15, 2012
Aside from checking you have power to it and the fuse inside connected directly to the cord is good:
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
Memorex MLTD2622... | Answered on Jun 15, 2012
Check ur tv original remote for a botton that said CC.Pushes this CC button a couples times to turn all functions like CC 1,2,3.. to all off.This will turn off all subtitle known as Closed Captionning.
Memorex MLTD2622... | Answered on Jun 16, 2011
use a vga to vga cable and a 3.5mm jack to 3.5mm jack lead like these
you will then need to to switch to pc input and your computer should display on the tv, if your using the tv as a secondary display from your computer. I.E. you already have a monitor connected or its a laptop you will need to go into display properties in your control panel and click on settings and then enable the second display.
Memorex MLTD2622... | Answered on Apr 22, 2011
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Memorex MLTD2622... | Answered on Mar 03, 2011
Any apple iOS device working with the netflix app is blocked by netfix from using component or composite cables connected to your tv. You can only view movies already on the device or photo slide show.
Hope this helps.
Memorex MLTD2622... | Answered on Feb 26, 2011
The dvd laser is probably faulty. The CD laser is still working. The complete laser unit will need to be replaced.
Memorex MLTD2622... | Answered on Feb 15, 2011
Memorex MLTD2622 26 in. LCD TV Logo
60 questions posted
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Ekse
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Memorex Televison & Video
Most Popular Question
memorex mltd2622 wont get power standby
  • Televison & Video
