20 Most Recent Toshiba Regza 52XF550U 52 in. LCD HDTV Questions & Answers
No pictur
Try removing the clips from both ribbon cables and re seat them, if that doesn't fix it chances are the Tcon board has failed
1/31/2018 8:24:49 PM • Toshiba Regza... • Answered on Jan 31, 2018
I have a Toshiba Regza 52XF550U which I purchased
Be sure that the setting in the TV is set to "AIR" NOT CABLE. After switching back, you'll probably have to re-scan. I'd bet that one of your connectors isn't crimped quite right. A single strand from the shield can kill the signal completely. If the center wire is too short or too long it can kill the signal. It should extend 1/16" to 1/8" beyond the threaded barrel part.
4/3/2017 6:57:25 AM • Toshiba Regza... • Answered on Apr 03, 2017
Sound on one channel from over the air antenna has suddenly become garbled. All others are fine.
If only one channel is affected it is not a problem usually with the set--it does not know what channel you are on---look in audio menu and make sure if set has SAP it is not on.
9/4/2015 11:12:41 PM • Toshiba Regza... • Answered on Sep 04, 2015
My Toshiba Tv will turn on, screen lights up, but no menu no channels, any suggestions?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
7/27/2015 8:08:45 AM • Toshiba Regza... • Answered on Jul 27, 2015
Half screen is blurred
if as it appears a LCD and problem is half screen is "blurred" the set uses two (or one large) boards and each drives the picture on half the screen---could be one bad, poor connection or worst case defect in screen unit (display panel) which would be fatal.
8/27/2012 7:10:17 PM • Toshiba Regza... • Answered on Aug 27, 2012
0answers
On the right side of the screen, there is about 4
I HAVE THE SAME PROBLEM CAN ANY BODY HELP US???
8/16/2011 8:01:07 PM • Toshiba Regza... • Answered on Aug 16, 2011
After three years, I now have one red line from
This tv problems it is causes by a bad dying board that call the T-CON decodering board.This T-CON decodering board sit at the bottom in the middle of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decodering board for the replacement.
8/6/2011 3:01:59 AM • Toshiba Regza... • Answered on Aug 06, 2011
The coloring on our sharp
Your problem lies in the board that handle the video processing. Unfortunately, I serched all the vendors I know and this part is no longer available.
4/4/2011 10:27:58 PM • Toshiba Regza... • Answered on Apr 04, 2011
I have a 52 inch
Perhaps an easy fix. Remove the back of the flat screen. There will be a main circuit board visible. There will be several capacitors, cylinders with a cross hatch on the silver top. Do any of them look like they have a dimple created by expansion of the internal capacitor material over heating? If you see an expanded top...that's probably your problem. Get your solder gun out and replace that capacitor. You can order a new one off of Amazon. If yours is a 10 volt capacitor, consider replacing it with a 16 volt unit. Generally the electronics companies under design the size of these units. When you replace the capacitor take note of the silver band on the unit and where its placed in the two socket holes....there is a positive and negative hole placement.
1/3/2011 3:57:44 AM • Toshiba Regza... • Answered on Jan 03, 2011
Thereis a 5inc line in
Faulty, if new return ASP Proof of Purchase
12/26/2010 8:25:21 PM • Toshiba Regza... • Answered on Dec 26, 2010
Toshiba 52xf550u has distorted vertical lines
All TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times reseating the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck.
8/11/2010 12:24:16 PM • Toshiba Regza... • Answered on Aug 11, 2010
2answers
Regza 52 inch LCD has a green and red line running
I have the same problem which started at about 10 months and became full blown after 14 months and now the warranty is up. TOSHIT BA 52u645
5/25/2010 9:14:05 AM • Toshiba Regza... • Answered on May 25, 2010
5answers
More of a Toshiba statement.
My 52 in regza has a vertical line on the right side as well just under 2 years old, out of warranty and to costly to repair, I paid $2500 as well. The TV has been on its stand since the day I bought it and has been moved once.
I have read of others who have this problem as well, just google toshiba regza red line, or vertical line
I Too will never buy Toshiba products and I will tell everyone I can about the **** LCD Toshiba
5/25/2010 9:03:43 AM • Toshiba Regza... • Answered on May 25, 2010
My toshiba 52
It junk now,only good for now,it only use for electronics componnents parts.LCD Screen replaced will exeed the new tv.Tv companies well not sell out LCD screen cheap,90% the tv is the LCD Screen and it limited amount when they produce it.
2/1/2010 5:50:41 AM • Toshiba Regza... • Answered on Feb 01, 2010
Can I use wireless headphones with the 42HL67US
Good wireless headphones have "line in" cable with 2 RCA plugs, which must be attached to TV's "audio out connectors. If you have only "optical" or "coaxial" audio stream out, you must upgrade your "wireless" gear to accommodate those signals. Forget about "headphone" jack! It's a blast of the past!Thanks,Alex.
12/4/2022 1:02:47 PM • Toshiba REGZA... • Answered on Dec 04, 2022
Toshiba Regza 52XF550U 52 in. LCD HDTV Logo
Popular Tags
26 questions posted
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
REGZA Toshiba
  • REGZA Toshiba
Most Popular Question
tv will turn screen lights up but no
  • Televison & Video
