20 Most Recent
Westinghouse PT-16H120S 16 in. LCD TV Questions & Answers
I have a Westinghouse 16h120S
Hello
Your Westinghouse TV has some kind of defect in the sound output section. Its sound output is rated to 2 Watts per channel according to its manual says It is a good sound intensity ypu must have to get. There is no sound output control lock is provided in it too. Therefore the fault must be related to its sound output section inside it.
The TV has mute function. If muting circuit have any trouble, this knd of fault may occur. Muting is done normally by using a transistor. If this transistor has some fault, like leak in its collectro to emitter junction, falult like this will occur, as this will reduce the volume voltage to less than required. Unfortunatly I can't point out which transistor, or wwhat ist number is, because, your TVs schematic diagram has yet to be publishe by the company.
Anyway it is sure that the sound output section of your TV is faulty. Before going further, I advise you to feed its audio out to any outer audio amp, and see if the amp is producing enough and undistorted sound out put. If it does, chek the speakers of your TV also for any kind of damage, by connecting its wire to an external good known speker. If you wants furthermore assistance, feel free to contact me through Fixya. OK.
Can I get codes that can reset my old Westinghouse smart tv
Yes, you can reset your old Westinghouse smart TV by using reset codes. The specific code you need may vary depending on the model of your TV. Here are some general steps you can follow to reset your Westinghouse smart TV using reset codes:
- Press the power button on your TV to turn it on.
- Using your TV remote, press the "Menu" button and navigate to the "Setup" or "Settings" menu.
- Look for the "Reset" option and select it.
- Enter the reset code for your TV when prompted. The reset code may be a sequence of numbers or a combination of buttons on the remote control.
- Follow the on-screen instructions to complete the reset process.
If you don't know the reset code for your Westinghouse smart TV, you can usually find it in the user manual or by contacting Westinghouse customer support. Keep in mind that resetting your TV will erase all custom settings and restore the TV to its factory default settings
Westinghouse WD55UW4620 no picture
Before you replace the power board, there are a few things you can try to troubleshoot the issue with your Westinghouse WD55UW4620 TV:
- Adjust the picture settings: It's possible that the picture settings on your TV have been accidentally adjusted, resulting in a dark picture. Try going into the TV's menu and adjusting the brightness, contrast, and other picture settings to see if that helps.
- Check the backlight: The backlight is responsible for illuminating the pixels on your TV screen, and if it's not working properly, it can result in a dark or dim picture. You can check the backlight by shining a flashlight on the screen and seeing if you can make out any images. If you can see images, then the backlight is likely the issue.
- Check the cables: Make sure that all the cables connecting your TV to external devices are securely plugged in and not damaged.
If none of these troubleshooting steps work, then it's possible that the power board is the issue. In that case, replacing the power board may fix the problem.
Backlights on Westinghouse WD50UC4300 TV flash and then go out.
It's possible that there is a problem with the protection circuit, especially if the backlights are receiving the correct voltage but are still not functioning properly. You could try checking the fuses or diodes on the circuit board that are responsible for protecting the backlights. It's also possible that there is a problem with the power supply or the main board that is causing the issue. If you're not comfortable working with electronics, it may be best to consult a professional for assistance.
Pass code for channel search on a Westinghouse tv model VR 4090
pass code's are typically setup by the user that sets up the tv. So, you could start my talking with that person first. If that person is not available, then you might need to factory reset your tv and setup it up again, provide the code to the tv and then write the code down (or email it to yourself) so you'll have it for future reference if you need it.
Thank you.
