20 Most Recent Lexmark X2600 InkJet Printer Questions & Answers
Printer lexmark ej error
The EJ error message on your model indicates that the print cartridge carrier has stalled. It could be due to the cartridges or the encoder strip (transparent strip found behind the cartridge carrier) has gotten loose from its position. Please follow steps below to identify and fix the problem:
  1. Open the printer cover and remove both the cartridges. Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
  2. Check the encoder strip and make sure it is secured in its place.
  3. Close the printer cover.
  4. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  5. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  6. If no error appears, reinsert the other cartridge. Close the printer cover.
  7. Replace whichever cartridge is causing the error to appear with a new cartridge.
  8. If no error appears, try to print a document again to verify that the problem is fixed.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
2/9/2021 10:41:41 AM • Lexmark X2600... • Answered on Feb 09, 2021
0answers
2answers
I can't scan with my Lexmark 2600m All-In-One
Make sure the Lexmark OCR scan software is installed on your computer. The scan software is available on the install disc that came with your printer. If lost the disc, please contact Lexmark Technical Support Center for additional assistance.
7/1/2016 4:24:00 AM • Lexmark X2600... • Answered on Jul 01, 2016
2answers
I print to my lexmark
error that the Lexmark Service center is not installed
7/1/2016 3:18:03 AM • Lexmark X2600... • Answered on Jul 01, 2016
Carriage for the ink cartridges is stuck, the
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
12/14/2015 5:10:00 PM • Lexmark X2600... • Answered on Dec 14, 2015
2answers
I have an ink refill kit and have used it with a
Hello!
Cartridges #14 and#15 can be refilled, but they won't work afterward, because they have a "smart chip" that blows the electric contacts on the cartridges (that is why Lexmark labels them as "return program cartridges").
You should buy #14A and #15A, those are refillable.
Hope that helps!
2/19/2015 1:02:09 PM • Lexmark X2600... • Answered on Feb 19, 2015
How do I download without my disk for x2600 Lexmark which I've lost.
You can launch the brand web site and select the model then download it. Just simple
12/14/2014 6:24:44 AM • Lexmark X2600... • Answered on Dec 14, 2014
What does error C5 mean on the Lexmark X2600 all in one printer mean?
hello For error C5 on an X2600 printer it means that you have a defective cartridge and you need to replace it. Please see link for more information: http://support.lexmark.com:80/lexmark/index?page=content&locale=en&productCode=&segment=SUPPORT&clearQuestion=Y&userlocale=EN_US&id=SO4438 Hope this helps.
8/28/2014 5:23:22 AM • Lexmark X2600... • Answered on Aug 28, 2014
2answers
Says paper jam and there is no paper jam
Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
8/16/2014 2:44:55 AM • Lexmark X2600... • Answered on Aug 16, 2014
Will not come on.
Hello, Check the power cord and make sure it is working and seated in the back of the printer and you have power too the plug. If after you have reseated everything and tryed powering up. If not work then take to local repair shop or call cust. support for the printer.
6/11/2014 12:18:51 AM • Lexmark X2600... • Answered on Jun 11, 2014
0answers
X2670
Be the first to answer 5/7/2014 8:00:10 AM • Lexmark X2600... • Posted on May 07, 2014Be the first to answer
Lexmark X2600 InkJet Printer Logo
714 questions posted
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
X Lexmark
  • X Lexmark
Most Popular Question
download free software
  • Office Equipment & Supplies
