20 Most Recent Lexmark X3650 Printer Questions & Answers
well remove the cartridges and ensure that there is no sticky tape across the printer faces
follow the instructions again
Lexmark X3650... | Answered on Dec 20, 2017
You can lastly try a hard reset of the printer but if that is to no avail the printer has an issue with it. See if you can get it to work with another computer for the heck of it just to make sure.
Lexmark X3650... | Answered on Aug 29, 2017
Hi str8fan69
Try first by downloading the latest driver for your device : http://support.lexmark.com/index?locale=en&page=product&productCode=LEXMARK_X3650&segment=SUPPORT&userlocale=EN_US&frompage=null#2
The WIA driver is included in Windows but you should first make sure the Lexmark driver is correctly installed .
You also can go to Start / devices and printers and check the printer there .
Best regards ,
fanaudi .
Lexmark X3650... | Answered on Aug 27, 2015
Go to this site and order toner cartridge.
http://www.quikshiptoner.com/catalog/scx-4300-toner.html?gclid=CjwKEAiAsJanBRCgnpfa0orvyz4SJAAbxEq-xJ9zH2DDpoSyBhf6QkwDk6r5jN2H52GrjAOaJt5BSxoCjLHw_wcB
Lexmark X3650... | Answered on Feb 19, 2015
Don't know if you have tried this, but it might help.
Create a scan to PC profile
1 Type the IP address of the MFP in the address line of your browser, and then press Enter.
If the Java applet screen appears, click Yes.
2 Click Scan Profile.
3 Click Create Scan Profile.
4 Select your scan settings, and then click Next.
5 Select a location for saving the scanned output file somewhere on your computer.
6 Enter a profile name.
The profile name is the name that will appear on the Scan Profile list on the MFP control panel.
7 Click Submit.
8 Review the instructions on the Scan to PC screen.
A shortcut number was automatically assigned when you clicked Submit. You can use this shortcut number when
you are ready to scan your documents.
a Go to the MFP, and place your original document in the ADF face up, long edge first.
b Press # followed by the shortcut number on the keypad, or touch Profiles on the home screen.
c After you enter the shortcut number, the scanner will scan and send the document to the directory or
application you specified. If you touch Profiles on the home screen, locate your shortcut on the list.
9 Return to your computer to view your file.
Your output file is saved in the location you specified or launched in the application you specified.
Good luck.
Lexmark X3650... | Answered on May 22, 2014
Have you tried removing the it, then installing it again. How have you got it connected? Have you tried connecting via USB?
Lexmark X3650... | Answered on Apr 14, 2014
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 3600 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Lexmark X3650... | Answered on Apr 05, 2014
dear friend .
Please check your power adapter or power cable by another printer if you don,t have so go to service centre
Lexmark X3650... | Answered on Apr 02, 2014
Hi, please explain what is your problem exactly. Do you have a problem with the scanner?
Lexmark X3650... | Answered on Sep 12, 2013
un snap the cartrige make sure its not leaking wipe it where the ink comes out of it with a klenex with alcohol on it and install it back in and if that dont work unpluf it for ten minutes plug it back in and see if that works if not replace the cartrige
Lexmark X3650... | Answered on Oct 05, 2012
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Lexmark X3650... | Answered on Mar 27, 2012
Lexmark X3650 Printer Logo
219 questions posted
Top Lexmark Office Equipment & Supplies Experts
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
X Lexmark
  • X Lexmark
Most Popular Question
print blurry
  • Office Equipment & Supplies
