20 Most Recent
Kyocera FS 1030D LASER 22PPM A4 PAR,USB 1200DPI DUPLEX Printer Questions & Answers
What location on the kyocera
Pull the multipurpose tray open in the front of the printer. There you will find adjustable side guides
to align the envelop as it feeds into the printer
How do you get it to pull from tray 2
Go into the printers on screen.
Go to the preferences of your printer by clicking on the icon.
Under one of the tabs, select that you have installed a 2nd tray.
It should then use it when available or when tray one is empty of paper.
My Kyocera 3700+ printer is printing fine but to
print is too dark, the drum was not charged properly.
- open the front cover softly
- there is a small blue guide move it 10 times to right and left
- the main corona will be cleaned you will get a good density
Error c6020
Raggy2010
posted on this toppic
Order the modified fuser plug connector. There is also a later firmware update to fix this code. This code happened to me on a few selected machines after I did firmware upgrades to add the interrupt button on the touch screen and to speed up the loading time. The thermistor is not guilty!
How do i print envelopes on a kyocera ecosys FS-1300d
Just a suggestion but in the application you are using, make sure the "Page Setup" is set to the envelope you need and the source for the envelope is correct.
Also, check the driver settings to make sure they match what the application needs.
Don
