20 Most Recent Sharp AR-208D Printer Questions & Answers
HOW TO REPLACE THE PRINT DRUM ON A SHARP AR-208D COPIER
  1. fold down the bypass tray on the right
  2. hit grey button on right door to open it
  3. fold the front cover down
  4. press green button to remove the toner
  5. the drum is the other thing you can grab and there and remove.
  6. reassemble in reverse order of 5-1
2/10/2015 10:54:40 PM • Sharp AR-208D... • Answered on Feb 10, 2015
HOW TO FIND THE IP ADRESS OF MY COPIER
The 208D had a network module on the back of it where the Cat5 cable plugs in. there is a little black button on there, if you hold it down it will print out the network config page. Copier Collin Houston TX Copier and Imaging Expert
2/10/2015 10:40:21 PM • Sharp AR-208D... • Answered on Feb 10, 2015
Need help for maintenance on Sharp AR208D copier
It is time to call the telephone number and request maintenance. When the copier gives you a message that it needs maintenance, the machine needs a trained technician to perform maintenance on it. Don't just keep using the copier as you can permanently damage the machine.
8/5/2014 5:45:52 PM • Sharp AR-208D... • Answered on Aug 05, 2014
manual
0answers
Won't print
Be the first to answer 3/15/2014 4:57:38 AM • Sharp AR-208D... • Posted on Mar 15, 2014Be the first to answer
Pages come out solid black
Your drum charger is not working.
1/8/2014 4:02:53 PM • Sharp AR-208D... • Answered on Jan 08, 2014
0answers
Sharp 208 s
Be the first to answer 6/25/2012 1:31:23 PM • Sharp AR-208D... • Posted on Jun 25, 2012Be the first to answer
Cannot installer scanner driver
You can download the Canon printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload : -http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
4/12/2012 8:34:17 AM • Sharp AR-208D... • Answered on Apr 12, 2012
2answers
I pulled the drum unit
Hello.
There is no trick, you just need to put it back properly until it is completely set in. Make sure it is the compatible drum though! If you are sure that it is compatible but can't fit it, remove it and try it again and apply a little force.
8/5/2011 2:20:33 AM • Sharp AR-208D... • Answered on Aug 05, 2011
0answers
Printing data has stopped printing data
Printer is out of ink
2/9/2011 7:53:08 PM • Sharp AR-208D... • Answered on Feb 09, 2011
2answers
Looking for the ip address
You can find Your ip address and Domain's ip address and Location of the ip address in this website http://www.ip-details.com/
12/17/2010 10:29:21 PM • Sharp AR-208D... • Answered on Dec 17, 2010
Printer not printing
check the data cable connection
8/23/2010 6:17:42 AM • Sharp AR-208D... • Answered on Aug 23, 2010
Sharp AR-208D copier needs developer - how to add?
Set-up for this copier sure isn't well-documented. We just got ours working today, found out how to add the toner by following the instructions here: https://www.businessneedz.com/Manuals/ar168s_setup.pdf (yes, it lists a different model number, but the instructions worked, and were linked from the ar-208d product page from the supplier)
2/23/2010 11:51:03 PM • Sharp AR-208D... • Answered on Feb 23, 2010
How add developer to sharp ar-208d
Set-up for this copier sure isn't well-documented. We just got ours working today, by following the instructions here: https://www.businessneedz.com/Manuals/ar168s_setup.pdf (yes, it lists a different model number, but the instructions worked, and were linked from the ar-208d product page from the supplier)
2/23/2010 11:50:14 PM • Sharp AR-208D... • Answered on Feb 23, 2010
Need to know how to add developer power to a sharp
No need developer.When your machine need developer,it show developer signal.blank page print means,charger problem please check corona wear may be it broken or displace.
1/15/2010 5:00:43 PM • Sharp AR-208D... • Answered on Jan 15, 2010
How do I put the developer in a sharp AR-208D
Hi, Hope you up to it, it not hard just messy.
To replace the dev the first thing we need to do it remove the developer unit, this done by opening the side door where the manual feed and then also open the front door, and remove toner cartridge and place on paper.
With the front door open you should be able to spot the dev unit with the toner hopper attached, their is one screw you will need to undo to allow the unit to come out of the machine. Remove the toner cartridge and place on paper
Now cover the work area, I use newspaper on customers floor or steal some big sheets of paper from the paper cassette and place a few on the ground because it can get messy...
Once you have the dev and toner hopper out we need to remove the toner hopper from the dev unit, there should be a few brass screws to allow the toner off the top of the dev tank
Put the toner hopper aside and we need to clean out the powder from inside the dev unit, it sticks to it via magnetism, so first I normally spill as much out on to the paper from the edge away from gear, and then while turning the developer driver gear clockwise, brush the rest out, it takes a bit, a few shakes, turns and brushes, but we need this old stuff out of the unit. I carry a vacuum, but it is designed for toner, I think it has a smaller filter where as normal ones tend to die from the metal filings in the dev..but if you have and old one then **** away, just don't scratch the magnetic roller with the tip
Once we have this clean, a little shake of the bag of new dev, rip the corner and pour it all in, if you run out of space or like halfway threw pouring turn the magnetic dev roller clockwise with the gear, this takes up the dev to allow you to put it all in, as we must.
Ok, clean the edges of the dev unit and refit the toner hopper, making sure it is fully down on the dev unit before refitting the brass screws,, refit the dev to the machine, keeping it level we do not want to spill it, it is important, fit its screw back in and slide in the toner cartridge, close the covers, and we need to then put in a couple of codes...
Put on the power, machine will run up for a bit, stirring the dev and mixing in toner, once we are at ready we can reset the developer counter.
Dev counter reset
Press "Clear" - "Interrupt" - "Zero" - "Interrupt". Machine will blank off
.(must be done quick)
Use the number buttons to make display read "42". Press "Print" button.
Machine will flash 00
Use quantity buttons to make display read "01". Press "Print" button.
Machine will flash 000
Press "Clear" - "Clear" - "Clear" - "Clear" and power machine off and back on.
If the maintenance counter needs to be reset too (indicater light is showing.)
then follow this one too
Maintenance counter re-setting
Press "Clear" - "Interrupt" - "Zero" - "Interrupt". Machine will blank off.
Use quantity buttons to make display read "20". Press "Print" button.
Machine will flash 00.
Clean up the mess we made, the stuff vacs up pretty well, I've tested that a few times, if it does get spilt, you will need another dev, if the level isn't correct it effects the print density...
Hope this helps, Cheers from Oz
Soulvisitor
Preform this procedure at you own risk. Incorrect entry of codes can disable machine requiring service call
11/11/2009 1:14:44 AM • Sharp AR-208D... • Answered on Nov 11, 2009
Sharp AR-208D Printer Logo
26 questions posted
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
find ip adress copier
  • Office Equipment & Supplies
