20 Most Recent Toto Aquia II Dual Flush Toilet Questions & Answers
Toilet bowl gurgles after flushing cycle
Sounds like your toilet is not vented properly. Possilbly something caught in the trap is causing it to syphon
4/3/2021 7:25:56 PM • Toto Aquia II... • Answered on Apr 03, 2021
2answers
How do i fix a cistern that is continually leaking
most modern toilets do not have an overflow pipe to outside instead they overflow into the bowl itself so have to adjust level so it does not overflow into return
5/29/2015 12:59:12 AM • Toto Aquia II... • Answered on May 29, 2015
Constantantly dripping after tank is full
WHAT IS DRIPPING,?THE TANK ?OR IS STILL FILLING UP ?IT SOUNDS LIKE YOU NEED TO ADJUST THE WATER LEVEL TO THE PROPER 1.6 GALLONS PER FLUSH,WHICH IS MARKED ON THE INSIDE OF YOUR TANK SOMEWHERE,CAUSE WHAT YOUR HEARING IS THE WATER RUNNING DOWN THE OVERFLOW TUBE
6/17/2014 8:51:07 PM • Toto Aquia II... • Answered on Jun 17, 2014
Invisi Series ll Round Dual Flush Plate & Buttons
That would be a leaking flapper valve. They are inexpensive and easy to install. Good luck I’m happy to help further over the phone at https://www.6ya.com/expert/robert_24775b73ca70da93
6/10/2014 8:48:47 AM • Toto Aquia II... • Answered on Jun 10, 2014
Not flushing all waste on first flush
Your inflow valve is probably clogged. This is what allows the water in and how fast. You can change this also for a minimal cost.
5/7/2014 5:39:30 PM • Toto Aquia II... • Answered on May 07, 2014
0answers
Toilet buttons will not come back up, hence water keeps running
Could be a few reasons, an ill fitting or cracked dress cover can sit to low, or abrasive wear and tear can grip the button restricting it from free movement. I fixed mine by placing a couple of small fishing sinkers in the bottom of the plunger giving it a little more weight.
4/30/2014 9:14:56 AM • Toto Aquia II... • Answered on Apr 30, 2014
0answers
How to fix
Be the first to answer 4/19/2014 3:28:57 AM • Toto Aquia II... • Posted on Apr 19, 2014Be the first to answer
Flush Valve leaking
replace the whole valve. It's cheap and easy to do. Probably you can install a universal valve. Look on e-bay or amozon I’m happy to help further over the phone at https://www.6ya.com/expert/robert_24775b73ca70da93
1/27/2014 10:00:42 AM • Toto Aquia II... • Answered on Jan 27, 2014
Assembly instructions
wear did you buy the unit
11/29/2013 11:02:06 PM • Toto Aquia II... • Answered on Nov 29, 2013
0answers
3answers
Push Button - Have to Hold Down Button
I had the same problem. The fix cost me 50 cents (literally). I just placed a quarter on top of the Blue and White flush buttons (not sure of the technical terms) inside the tank and now it flushes properly. It seems that the 2 plastic poles the extend from the faux chrome buttons are just a bit too short.
Hope this helps
11/2/2013 12:13:32 PM • Toto Aquia II... • Answered on Nov 02, 2013
The dual flush push button flushing unit on my
the connection rod under the lid is broken or not making the connection just lift the lift to see.
10/6/2013 6:46:24 PM • Toto Aquia II... • Answered on Oct 06, 2013
Toto Aquia II Dual Flush Toilet Logo
121 questions posted
Top Toto Home Experts
john h
ZJ Limited
ZJ Limited
Are you a Toto Home Expert? Answer questions, earn points and help others
View Most Popular
Toto Home
  • Toto Home
Most Popular Question
toilet buttons will not come back up
  • Home
