20 Most Recent
Coleman Powermate Subaru 5000W Portable Generator Questions & Answers
How much oil will a
When I change mine I believe it takes just under a quart....
once you get half the bottle or so in your need to start checking the dip stick...
heatman101
10/25/2018 7:20:56 PM •
Coleman...
Answered
on Oct 25, 2018
Will not generate electricity
First verify that the breaker for the outlets is not tripped and make sure that the generator is running at full operating speed. let it run for 5-10 minutes and check for output power. If there is nothing, there are two possible problems. One could be that the automatic voltage regulator is bad. The other is that the field needs to be flashed - a high possibility if the generator has not been run in a long time. There are many videos on the internet that show you how to solve both of these problems. Just do a search for No output from a portable power generator.
6/24/2014 11:25:06 AM •
Coleman...
Answered
on Jun 24, 2014
On a Generac model 1646-2 generator is the oil level switch normal open with full oil level.
I don\'t know, but change the switch or bypass it. They give plenty of problems & motor would start sometimes & not others.....Check the oil & rely on old style tech. I bypassed the switch on both of mine.after they gave problems & wouldn\'t run when needed....I only got a second one when I needed power & the switch was the only thing wrong ( I found this out too late.) & ended up with 2....
6/21/2014 10:44:22 AM •
Coleman...
Answered
on Jun 21, 2014
Jump sart car with generaTOR
There is not enough amperage in the generator to jump start a car. You risk damaging the generator. NOT recommended
11/23/2013 1:00:23 AM •
Coleman...
Answered
on Nov 23, 2013
How do i disconnect the low oil sensor
Some oil sensors will stop the generator from running if unplugged, IE they close the circuit on oil pressure, some close the circuit on oil pressure. I wouldn't recommend but with it running just take the single wire off the sensor, if it stops immediately then it requires the signal grounded to run. Some ground on low oil.
11/15/2013 11:49:10 PM •
Coleman...
Answered
on Nov 15, 2013
