20 Most Recent
Kraft POW R KRAFT 65575 7 ton 2 Speed Electric Log Splitter Questions & Answers
Ram moves jerkily and then doesn't recoil
Check hydraulic fluid and ensure it is at the proper level - Still have the problem
Check hydraulic filter...may be clogged.
Check hoses and ensure there're no leaks.
Good Luck,
Mike...
Kango 950 motor runs but hammer only engages sometimes
This is an indication that the hammer needs service. When you take the barrel off you will see the striker. There is a piston inside the striker, when the rubber rings on the piston wear out you have the problem you describe. time to replace the motor brushes clean and regressed, make sure to use the correct grease, Check the backlash on ring and pinions. Don't put too much grease on the piston or it will stick and not strike. Good luck I forgot to ask which version. This is for the uk atlas coco, silver with blue or red handle
5/29/2022 2:06:56 AM •
Hammering
Answered
on May 29, 2022
Where can I get a set of brushes for a kango 950X
Unfortunately, you won't find them - Kango was a great hammer, but the company has been gone for many years and there are no parts available.
I would find a local repair shop that may have a different brand brush that is the same or bigger dimensions - by using a piece of 220 grit sandpaper on a hard, flat surface - you can sand them down to the proper size.
It will get you out of a bind
3/3/2021 2:37:44 PM •
Hammering
Answered
on Mar 03, 2021
Which type of oil for rok demolition hammer thank you
If an oil sight glass is in the modelrange of the brand ROK Rottela 40 , but if no sight glass is used in the model then often is to use special Grease lubrication. or only an special volume of oil and most used of them are zinc-free hydraulic based and included in the manual instructions of a maintenance set (service kit)wear parts set.
5/29/2019 9:53:04 AM •
Hammering
Answered
on May 29, 2019
Switch for kango 950 S
- The total condition of the seal anvil piston and striker are very important for the total condition of impact when spending a service kit (maintenance) when there is leakage at the front part everything will be hot inside and the rings will harden again quickly.
kango 900 950 round switch housing
8/16/2018 7:56:48 PM •
Hammering
Answered
on Aug 16, 2018
