20 Most Recent
Groove Tubes Power Back 5,250-Watt Portable Generator #GT5250-WK Questions & Answers
My powerback 5250 portable generator
remove the tap from the tank
they have a habit of corroding internally and blocking the fuel flow
there is also a very fine filter in the end of the tap in the tank
do not use e-mix fuels as that fuel corrodes aluminium and rusts steel
Oil type
If you are asking about the engine oil, generators like the 10W 30 weight oil, which is good for winter and summer use. . The brand doesn't matter to any gret extent. Just don't buy the el cheapo brand in the dollar store.
Power Back generator model GT5250
You definitely have a carburetor problem.
If your carburetor has sat for a few months with fuel in it,
the fuel may have gone bad. Fuel turns to turpentine after a while and
leaves light yellow deposits behind. These deposits will keep your carb.
from working properly.You need to dip the carb. in carburetor dip for a
few hours to get rid of the deposits. You can also take the carb. to
your local parts store where they may do it for free.
You
may also have to replace the gasket and needle valve too if it has been
sitting. So basically, you need to do a carburetor rebuild. If the float sounds like it has liquid in it, you will need to replace it too.
Good Luck!
Jim
