20 Most Recent Chicago Pneumatic Qrs 5 HP/3 Phase Rotary Screw Air Compressor Questions & Answers
2answers
Can i convert a 3 phase 10hp qrs compressor to single phase?
Search the 'net for phase converters. I have read articles about making your own phase converters from old 3 phase motors----Fine Woodworking mag.
4/6/2023 11:49:45 PM • Chicago... • Answered on Apr 06, 2023
4answers
How to find a 3 phase compressor tonnage by it's
how to check compressor lra to converta ton
2/23/2020 2:30:20 PM • Chicago... • Answered on Feb 23, 2020
0answers
Lra compressor
Be the first to answer 1/5/2014 9:50:08 AM • Chicago... • Posted on Jan 05, 2014Be the first to answer
I have a qrs 10 air compresser gettting water in air lines and it has a air dryer
When the compressor at work allow the water to get in the lines the solution is to replace the filters in the dryer as they are blocked and the air bypasses them to get to the system. Check to see if that is the same problem
8/9/2013 7:04:58 AM • Chicago... • Answered on Aug 09, 2013
Compressor will run but not produce air
Check your safety valve is closed by pulling it out and releasing it. You can use a mixture of dishwashing soap and water to drip on the valve to see if it makes bubbles identifying a leak. Next make sure the petcock valve on the bottom of the tank is closed and not leaking by using the soapy water again. If you cannot close or fix the valve replace it. The next trouble shooting will require checking the air input to the tank but be careful since the tubes could be hot.
8/18/2010 4:13:19 PM • Chicago... • Answered on Aug 18, 2010
We have 15 HP motor screw compressor of cp make in
Sounds like check valve doesn't close fast enough. COuld have broken spring. Also if oil level is too high that could cause it.
5/26/2010 9:07:37 PM • Chicago... • Answered on May 26, 2010
I have oil leaking out of the air inlet filter
If it is an oil bath air filter, overfilling the filter could do it.
If there is excessive vibration that could cause it.
Possibly during shutdown some backflow of air occurs.
11/17/2009 3:52:59 PM • Chicago... • Answered on Nov 17, 2009
In CPB30 screw compresser lub oil leak in air
ussually it comes from being shut off while its running. allways make sure that its quit its cycle and is not running before you shut it down.if your not going to be using it for a while as in going home for the night it is a good idea to turn it off to keep power outages from doing so
9/18/2009 1:32:47 PM • Chicago... • Answered on Sep 18, 2009
Can't put socket sae 1/2 deep wall socket 69560 on 61718 wrench
bad seals on the compressor ... or the hoze has a micro fracture... {dead preasure test it} also check the output nozzle has no dirt..
6/4/2015 10:11:24 PM • Chicago... • Answered on Jun 04, 2015
How do I set the drill to hammer setting?
ther is a picture on the drill to show you wer it is turn it too it and away you go
7/29/2014 1:03:17 PM • Chicago... • Answered on Jul 29, 2014
I bought Chicago 80 p rotary set without instruction
Dude!!!!!! This is NOT a Chicago tool nor is it pneumatic! Chicago tools are air powered. This is a rotary tool. Looks like a very nice one at that. The world leader in rotary tools is Dremel. Although the tool you have is not a Dremel. I am going to direct you to their website as they have a great introduction to rotary tools, they explain how-to and give details on all of the attachments and what they are for. They are also explicit on safety and give detailed safety instruction. I personally have four different Dremel tools and hundreds of attachments, if you need any advice on any of things please feel free to contact me again. This will Fixya!
http://www.dremel.com/en-us/customerservice/gettingstarted/Pages/default.aspx
2/28/2009 5:41:26 PM • Chicago... • Answered on Feb 28, 2009
How much should good scaffold brick guards cost me?
These should be expensive, but they are nothing of the sort. You can pick up quality scaffold brick guards online for as little as £3.99. I use a company called BrikGard because they use 100% recycled plastic scaffold brick guards. I like to be as environmentally friendly as possible without compromising quality or increasing the purchase cost too much. Given that their brick guards are so cheap and made from 100% recycled plastic, I feel safe using them. Also, anyone working on-site should consider using a brick guard because it offers that extra layer of peace of mind so you can get focused on the job without worrying about things like falling debris coming down and striking you. For affordable scaffold brick guards, I would check out BrikGard.
3/18/2024 5:15:05 AM • Tools & Hardware... • Answered on Mar 18, 2024
Chicago Pneumatic Qrs 5 HP/3 Phase Rotary Screw Air Compressor  Logo
Popular Tags
13 questions posted
Top Chicago Pneumatic Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Chicago Pneumatic Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Chicago Pneumatic Tools & Hardware - Others
Most Popular Question
compressor will run but not produce air
  • Tools & Hardware - Others
