20 Most Recent
Jet 710115K Jwbs 14CS Deluxe 14 Inch 1 1/4 Horsepower Woodworking Bandsaw With Micro Adjustable Blade Guides, 115/230 Volt 1 Phase Questions & Answers
Tire comes off wheel
Are you using new tires? Urethane or rubber? Make sure the adjustment are correct or probably you need to replace the tires. I am using ulta blue urethane tires because it lasts longer and it doesn't need gluing. Urethanes are more durablethan rubber. I got mine on http://bandsawparts.com/ultra_blue_urethane_tires.cfm .
Top wheel part broke off
I suspect the part you need is 150086 "Upper Wheel Shaft". You can confirm this by checking the exploded diagram for your bandsaw which can be downloaded at http://content.wmhtoolgroup.com/manuals/708115K_man.pdf.
See page 25 for exploded diagram showing wheel shafts, bearings, etc..
It might be worth checking with JET about warranty since I believe that band saw has a 5 year warranty. You can check
here for a service center near you.
Therma Overload Switch
If you have not supplied enough power (like using an extension cord) the motor sees a big voltage drop, starts drawing a lot of current and eventually overheats. Make certain to use a good supply.
JET Tools
2/5/2015 9:19:38 PM •
Jet Saws
Answered
on Feb 05, 2015
How do i adjust the blade tilt
There should be 2 handles: height and tilt. Tilt is typically located perpendicular to the blade on the base of the saw.
1/28/2015 8:38:11 AM •
Jet Saws
Answered
on Jan 28, 2015
How do i adjust a jet bandsaw jwbs-9 blade tension
You should check your manual. There's a blade tension handle on my bandsaw, which is adjusted every time I need to change tension or change blade. There ways how to check the correct tension, you can pluck the blade like a string on a guitar and if you hear music not like sound, tension is good. Or you can follow the suggestion blade tension on your saw. or you may also use tension gauge.
7/25/2014 6:53:18 PM •
Jet Saws
Answered
on Jul 25, 2014
