20 Most Recent
Sportline 345 Electronic Pedometer Questions & Answers
How or what do I slide to change battery?
To replace the L1154 battery, pull the back cover off using the notched plastic lip. The battery slides out laterally by slightly lifting the outer notch on the battery holder.
I need a manuel for a go walking stopwatch by sportline
First, press the mode button (the one in the middle) until either the alarm set screen or the time screen shows. Second, while in the alarm set or time screen, simultaneously press the split/reset select button and the start/stop set button (the two outer buttons). The alarm symbol should go away (this is normally in the upper right corner of the screen).
How does a pedometer measure distance
There is a little weight that moves up and down every time it is shook (i.e. a step is taken). It uses an average human stride length (some can be adjusted) to calculate the distance.
