20 Most Recent
Odyssey Steel 2 Ball Srt Putter Questions & Answers
Fixing a worn-down putter face
most golf stores can replace the face plate for about $25 but you can buy the part and do it yourself part $7 and a bottle of contact cement $3
I've lost one of the
I would suggest you go to your local vinyl sign maker get him to cut a new pre stick disc and stick it on
I am trying to remove the shaft from an Odyssey
Rosemary, I found a broken Ping putter in the trash can and took it to a golf repair place and they put a new shaft in for not too much money and it was a great putter for many years before I needed a belly putter to help me keep the putter more steady.
Drivers seat is tilting back and forth
it can be a spring that came loose from its spot under the seat look to where it should be or the seat could be back to far and it depends on how old it is if it has just broke down make sure nothing it in the way and the lever id not stuck hope this was helpful:)
Hi we need a manual
Hi Linda, i have the same 1983 Travelaire motorhome Econoline F-350 26ft and are in search of the Shop/owners manual ... Do you know where to find one ?
I am located in BC Canada
Reg 250-379-2971
[email protected] if you can contact me ?
