20 Most Recent
Eureka Luxury Family 8-Person 2-Room Titan Tent Questions & Answers
Hhow do I put
carefully follow the steps below:
Locate and purchase the correct belt for your Eureka vacuum cleaner from
the local grocery or department store. Vacuum belts come in different
sizes according to your model of vacuum. Check your owner's manual or
the vacuum itself for your model number.
Turn your vacuum cleaner over so that the bottom of the unit is facing
you. Remove the cover plate from the bottom by undoing the screws that
are holding it in place with a screwdriver.
Locate the belt pulley rod near the back of the vacuum base coming out
of the motor. With the vacuum cleaner base turned upside down and facing
you, the motor and pulley rod should be up near the top of the base.
Slide the vacuum brush roller out of the slots at the bottom of the
vacuum base and remove the old belt from the brush roller and pulley
rod. With the brush roller off of the unit, clean the brush by removing
any strings or cords wrapped around the tube.
Install the new belt by looping it over the belt pulley rod next to the
motor and then looping around the end of the brush roller in the belt
slot. Hold the brush roller and pull back on it to tighten the belt
while you slide the roller back into the slots on the vacuum base.
Replace the base cover plate by snapping it back into place and securing
it with screws. Turn vacuum back upright and turn it on to test the
belt and verify the unit is working.
I wish you the best of luck as you follow the steps above.....
Regards.
Looking for a repair manual,
Contact Ozark Vacuum in Rolla, MO. Don't know if a repair manual, per se, is available or will be free but their knowledge should be able to help with your issue.
I own a Eureka Cordlessw
You can download the complete instruction manual in PDF format by clicking this
link
- You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using
FixYa.
9140
if u dont kno how to change a belt then get a life
How do I change the belt on a Eureka Victory model
You need a phillips screwdriver. Undo the two screws, either side of the height adjustment dial. Lift off the cover. Now you should be able to see instructions and the old belt..
Remove the brush roll..put the new belt in place around drive pulley and brush roll pulley.. reinsert left end of brush roll first then pull to stretch the belted end back into it's place.
Replace cover.
