20 Most Recent Siemens HF17055GB Microwave Oven Questions & Answers
The motor needs to be replaced.
Siemens... | Answered on Jan 18, 2018
Replace the motor. The teeth in its gearbox have probably been damaged when trying to turn the plate by hand.
Siemens... | Answered on Aug 25, 2014
Roger, lay your microwave on it's back after taking your turntable plate out of the microwave. Looking at the bottom plate you should see in the middle an area that covers your motor that should be square, a rectangle, or a circle. There usually is also a screw that is just screwed into the bottom plate. Around the middle part, whichever shape it is, there will be a series of small holes with a thin piece of metal going between the holes, get a pair of side cutters and snip the thin strips of metal and that will give you access to the motor when they are all snipped out. To replace it you usually just have to turn the plate 180 degrees and use that screw to hold it back in place. Hope this helps.
Siemens... | Answered on May 29, 2014
What part cuts out? The power to the whole unit? Just the magnetron? Fan? Display?
Siemens... | Answered on Nov 30, 2013
see this steps and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#11#ixzz2YvqJdpSm
Siemens... | Answered on Jul 13, 2013
I have never been paid but answer questions through the goodness of my heart ..I am sorry to hear of your plight, contact customer service...
Siemens... | Answered on Jan 31, 2011
Yes. You can fix it. The problem is that the touchpad is bad. If it is a HF17055GB let me know, and I will give you the part number fro the touchpad. Or you can call locally and get the part number from a Siemans appliance dealer in your area. The new part will come with detailed instructions on how to install the part. They are not real difficult to install.
Julie please go through your manual there are some buttons you need press to get the microwave working
Siemens... | Answered on Jan 19, 2011
Siemens HF17055GB Microwave Oven Logo
38 questions posted
Top Siemens Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Bill Olaschinez
Are you a Siemens Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Siemens Microwave Ovens
Most Popular Question
replace turntable motor
  • Microwave Ovens
