20 Most Recent
Intimus 280 Shredder Questions & Answers
Shredder stops - red light off
Some shredders are great for thicker paper. If you put a thicker piece of card through, it should activate the switch located in the middle of the shred blades. The paper might be too light to push it forward. Also, if you click the feed catch beyond it's operating position, this can also stop the shredder with no lights.
Red indicator light always ON mode but the unit is
This can be caused by more than one problem.
The bucket it not properly placed under the shredder or the safety switch is stuck or bad. I am sure there is also other reasons the could cause the red light staying on.
Intimus 280 shredder noise
The 280 is notorious for buildup of paper in the cutting cylinders and strippers.
If you are technical, unplug from wall, disassemble top cover and clean all the debris. Check nylon strippers (white plastic) for damage.
