20 Most Recent
Siemens Freezer GS 28E420 Questions & Answers
My door handle is broken- can I fix it?
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
I have a siemens KG39P320GB alarm went off ,
Let's check the start relay first and feel the top of the compressor. Is the compressor hot? Not sure where you are located and where you can find parts but the start relay and run or start capacitor if it has one can be matched at most refrigeration part suppliers. A three in one by
Supco would be perfect if avaliable where you are located. The above photo is only an example. I'm here if you need me, Thanks
Sea Breeze
The ligt stays on with the door closed but not at
The door switch that is pushed when you close the door is probably not being pushed far enough. Push it all the way with your finger and see if the light goes off. You may can clean the switch or just replace it.
Freezer is Frozen shut
Try unplugging the freezer and leave the door open for about 30 to 45 minutes. Don't forget the door is open and plug the freezer back in. Set a timer in the kitchen so you don't forget. Once you can open the drawers look inside the freezer sides to find the controller. Most models have turn dial inside.
Siemens GI12B40GB/41 freezer full of ice. If
Hello there,
When ice is building up on the outside of the drawers and on the element in 2 days. Then it means there is a problem with the defrost system of the refrigerator.
You need to run a test on three components inside the refrigerator, which are the defrost timer, defrost thermostat, and the defrost heater.
Once the three are tested, you will be able to get the faulty component and know how to replace it. here are links to tips on testing your faulty component.
Defrost heater
http://www1.fixya.com/support/r10523771-test_defrost_heater
http://www1.fixya.com/support/r10523754-replace_defrost_heater
Defrost thermostat
http://www1.fixya.com/support/r10513592-test_defrost_thermostat
http://www1.fixya.com/support/r10513650-replace_defrost_thermostat
Defrost timer
http://www1.fixya.com/support/r10523722-test_defrost_timer
http://www1.fixya.com/support/r10523742-replace_defrost_timer
Hope this helped.
All the best
Elect_Comp
