20 Most Recent Maxtor OneTouch II 100 GB Hard Drive Questions & Answers
No backup option at all. Hd express loaded etc..
try going to this site this is the latest maxtor backup software
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=retrobackup&vgnextoid=c6773428ab622110VgnVCM100000f5ee0a0aRCRD
5/11/2009 6:31:45 PM • Maxtor OneTouch... • Answered on May 11, 2009
7answers
Re: Maxtor External 100GB one
Hi
check this link
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot4-downloads&vgnextoid=0ed72c9e46914110VgnVCM100000f5ee0a0aRCRD
thank you
10/26/2008 11:45:51 AM • Maxtor OneTouch... • Answered on Oct 26, 2008
I have the hard drive,
well connect the hard drive to your computer by the USB
and run the installation CD provided.
that should be it
9/3/2008 8:37:44 AM • Maxtor OneTouch... • Answered on Sep 03, 2008
HELP!?!? E:// is not accesible the file or directory is currupt and unreadable
Have you checked the usb wire or ports from and to the hard drive?
2/19/2008 3:47:22 PM • Maxtor OneTouch... • Answered on Feb 19, 2008
Errors when Backing up information from hard drive.
I have several drives backed up and they work fine whenever they are imaged. anyway.. These drives are made for use in Windows and Mac enviorments. It is usually MAC users that have this problem.They are usually preformatted using fat32. because the drive is usually for storage fat32 is sufficent...but there are certain characters that fat32 dosen't care for...Do you have file naming scheme that uses odd characters? if so Those are the file names the error is refferring to. You may choose to reformat the drive using fat32(again) or NTFS(note fat32 has a better chance of data recovery just in case)your main hard drive might be NTFS. The rest is only important if you use a MAC Now if you have a MAC see below. How do I initialise the external drive for Mac OS X? Preparing the Seagate/Maxtor external hard drive in Mac OS X Mac OS X cannot mount a FAT32 partition larger than 137 GB (128 GB binary value). Our partiton is 160 GB (149 GB binary value). Since your external drive comes with a large FAT32 partition preinstalled you will need to initialise the drive to use it in Mac OS X. WARNING: Initialising or partitioning the drive will erase all data on the drive. If you have used this drive on another computer take the drive back to that computer and copy all data off of the drive before proceeding. When the drive was plugged into the Macintosh you probably noticed a message reporting an error that it cannot read the volume. At this point you have the option to initialise the drive. If you missed that message you can initialise the drive manually. Initialising the drive in OS X If you see the volume error, you can click the Initialise option. If you do not see it, then go to Finder > Applications > Utilities > Disk Utility. In Disk Utility: Select the external drive (149.05 GB). Be sure you select the correct drive before proceeding. If you have more than one 160 GB drive then be sure to select the correct one. 1. Go to the Erase tab. 2. Choose the type of partition (Mac OS Extended). 3. Type a volume label. 4. Tick the box that says "Install Mac OS 9 drivers". If this option is not selected, this device cannot be used by a computer running Mac OS 9. This option does not affect Classic. 5. Click Erase. 6. Read the prompt and Click on Erase again if you agree to erase all the data and you are sure the correct drive is selected. 7. The drive will now show on the desktop with a Firewire icon and the volume label as the name. Additional Information For more information on the FAT32 partition size limit in Mac OS X please read document number 107483 on Apple's support web site. For more information about formatting drives in Mac OS visit Apple's support web site. For more information about decimal versus binary capacity values visit our FAQ on the subject. Let me know what happens. Good Luck, Tim
3/16/2007 7:30:48 AM • Maxtor OneTouch... • Answered on Mar 16, 2007
Maxtor 3200 manual for Mac
Link 1 https://drive.google.com/file/d/1ec_BG1BrTXhPWyMgJtbfMAAmrV1lrTY7/view?usp=share_link Link 2https://drive.google.com/file/d/1Wni-u68YQaeCs7eMNhgIEeUgg1fRUO0Q/view?usp=share_link
1/10/2023 4:33:14 PM • Maxtor Computers... • Answered on Jan 10, 2023
2answers
Maxtor External Hard Drive No Power
I assume it is a USB connection? Does it also have a power adaptor or a USB dongle that has 2 USB connectors? If you cannot get it to power up, the only other option to retrieve your data is to take the HD out of the case and connect it to a PC or laptop using a SSD or SATA to USB adapter and see if you can get the PC to recognize it.
10/26/2021 10:57:06 PM • Maxtor Computers... • Answered on Oct 26, 2021
Where can I download the drivers for Maxtor Diamond max plus 9 120gb ata/133 HDD
I doubt they are still available but usually one can be found on the maxtor web site, (many years ago).
6/26/2021 3:51:04 AM • Maxtor Computers... • Answered on Jun 26, 2021
My Maxtor 1000GB harddrive has stoped working. PN:9NZ2D8-500. SN:2HBECHWY. It connects by a USB and powed by a transformer that was supplied by Maxtor. All of the parts are about two years old, brough
I replace my hard drives after 2 or 3 years. Yours seems to have quit early, possibly the transformer is not working. If your external drive lights up, the electronics could be bad. At any rate, the bad news is it sounds like time for a new drive. I hope you have a backup of the contents.
12/23/2017 10:06:22 PM • Maxtor Computers... • Answered on Dec 23, 2017
My Maxtor M3 is showing titles of documents stored from my former office PC but the files will not open on my laptop, other than those with attachments in PDF format, which do open
The application that was used to create those files is not in your laptop. Ergo, they cannot be read.
8/19/2017 3:56:23 PM • Maxtor Computers... • Answered on Aug 19, 2017
Maxtor OneTouch II 100 GB Hard Drive Logo
8 questions posted
Top Maxtor Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Maxtor Computers & Internet
Most Popular Question
no backup option all hd express loaded
  • Computers & Internet
