20 Most Recent
LG Secret ? KF750 Cellular Phone Questions & Answers
I have the lg secret
hey guys, i had the same problem and fixed it :) you should only change your primary storage settings:
settings-memory manager-primary storage settings-external memory
your handset memory is full and that's why your phone rejects bluetooth transfers :)
LG Secret
hey! i also had the same problem. i could only send files through bluetooth but couldn't receive them but recently i found out it's becuase my handset common memory was full. so if you delete some files u have on ur handset memory..u may be able to receive files again. this worked for me but im not sure if you have the same problem as i did. i thought that the files received on bluetooth would go to my mircoSD memory chip thingy but apparently it didnt. SOOOO if ur able to send files through bluetooth it should mean that the bluetooth connection itself isn't the problem....i think. it's just ur handset common memory that is full. u can go check the memory space by going to Setting ->Memory manager ->Hanset common memory.
Hopefully this helps!
Delete outbox massages
When the "sent" folder reaches its maximum limit, mail in the "outbox" cannot be moved to the "sent" folder. Delete the messages in your "sent" folder and it should work for you. Let us know how you go!
Video message keeps saying message capacity is exceeded
I think its nothing to do with the memory available on your mobile. Every phone has a default capacity to send or recieve MMS(i.e your video message). If you try to send a message that is bigger than this limit u will get this message.
Master Reset LG Lotus
1. Press Main Menu .
2. Select Settings .
3. In Settings select Reset settings .
4. Select Restore default settings .
5. Enter Security code as 0000 and press Ok .
I forgot my mobile security code
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
LG KF750 USB problem
Try going into your connectivity option, then USB connection mode.
Select Mass storage.
