20 Most Recent
Canon PowerShot SX110 IS Digital Camera Questions & Answers
All of the pictures are grainy and very dark- not
To fix your issue with the Canon Powershot SX110 IS Digital Camera, try cleaning the lens. A huge issue with malfunctioning pictures can be as objective as a dirty lens. If that doesn't solve the issue, try to make sure that your flash is working to its full power. If you are taking a picture in a low-light area and the flash isn't giving off a strong enough light, this will cause grainy/noisy dark photos. Lastly, try playing around the with settings on the configuration screen. Sometimes digital cameras can malfunction, even after reformatting, and will apply alternate settings from what you originally had set.
Hope this helps!
-Anonymity
Canon PowerShot SX110 IS Digital Camera charge fully battery after one pics show low battery sign
This is probably a battery issue and not a camera issue. Batteries with low output or low power can be due to them sitting and not being used for long periods of time. This can affect their ability to get a full charge as their "memory" is reduced regardless of what the charge light indicator displays. Even taking a battery that has been sitting for a long period and charging it to full charge, might only have limited power. Some of these can be returned to almost full capacity, but it takes multiple, repeated, alternating, charges and power deletions to rebuild the memory. In many cases, however, the battery just needs to be replaced.
Auto and manual setting not working
Ana, That is not much to go on, but I will try.Not working, is that you don't see any response on the camera? does the screen go on, and not telling any error message.Or does the camera go on and you just can't make any picture?Most problems occur when the batteries are old or the battery contacts are dirty (oxidised) be sure the contacts of the batteries and in the camera battery compartment are clean. Be sure your batteries are not worn out. Test with a set of new ones.Look if accidentally your memory card is locked. the switch should be pointing to the top (where the golden connection point are).If you still have a problem, please let me know.
Where is the self timer button?
It's the button marked with a one-handed clock. In shooting mode, press cursor-down, then use cursor-up/down to select an option.
Why will my memory sd card not snap into place?
There is a small retaining clip in the memory card compartment which snaps into place when the card is inserted to hold it in. Maybe this has either become stuck, is broken or is jammed into place. If you see it, then try wiggling it a little bit to see if it goes back in to place.Hope this helps.
