20 Most Recent
Vivitar 3-in-1 Digital Camera Questions & Answers
I DONT HAVE THE INSTALATION DISK FOR MY VIVITAR 3 IN 1
In a lot of cases, when you fire up your pc with the camera plugged in, the pc will say found new hardware. Just let it run. When it is done, go to my computer and your pc will gain another drive. This drive is youor camera. Use programs on your pc to process pictures.
I would like to get
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
I do not have the software. Is there any way i can
Hey, I had this exact same problem the other day, but after hours of searching, I finally found this. It contains everything that you will need. Here's what to do:
- Extract the files to a folder.
- Open it up, and click on "Setup"
- Follow the on screen directions, and restart your computer.
You should now be able to download the pictures from the camera.
Thanks for using FixYa!
Hello ive got a mini
Hey, I had this exact same problem the other day. After hours of searching, I finally found
I have a vivitar7340 when i turn it on i get a special lens error
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
It won't turn on
When you unplug it, are you using the "safely remove hardware" function on your computer?
