20 Most Recent
Fuji Finepix J50 Digital Camera Questions & Answers
Very poor quality pictures; grainy.
This is easily fixed - go into MENU and you will find a picture quality Q. This is designed to go from FINE - Medium - POOR in order to enable you to take more photos on you cameras memory. Install at least a 1gb memory stick into your camera and then choose HIGHEST QUALITY you will now be able to get plenty a photos at the highest quality possible gor the camera with an 8.2 megapixal those photos should be really nice. Have Fun Lancer721
Show me what I have to do to get my photos from my fujifilm finepix J50 camera onto my laptop
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
I have pictures on my camera hard drive the I can't get off
Two ways:
- Use the "Copy" command in the playback menu to copy the pictures from the internal memory to the memory card, then download the pictures the same way you normally download from the card.
- Remove the memory card before using the USB connection to connect to your computer, then download the pictures from the camera.
You may download a copy of the manual
here.
Camera is locked up. screen says it has a 'protected card'
there's a write protect tab on the card. if this is in protect them you can't write to it [save photos]Also, if the tab is in the right position, the sensor in the camera is either blocked [optical] or damaged [electro-mechanical]If it's blocked, use 'dust off' canned air to blow out the card slot.If it's a switch, it'll have to go in the shop.Hope this helps.
How do I upload pinepix j50 images without
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Usb purchased and another one
Consider NOT connecting your camera to your computer.
The camera says !FOCUS ERROR whenever I turn it on
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
Lcd screen goes on
If your pictures after shoot are coming out well when downloaded , then it is the LCD display - the monitor to your view - that is faulty as the camera section is intact.
So if this comes on and then blanks out there is a possible chance that the Display is faulty, the driver to the display , possible electrolytic capacitors in the circuit or a wiring link to the LCD.
Remove and check only if confident and experienced but do not tamper a working camera.
I cannot load my pictures from my camera onto my
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
How do i upload pictures from finepix j50 computer
My screen is blank (white) and has USB on the
Try taking the batteries out for about an hour, put them back in and try it. It seems to be stuck in USB mode which can only happen with a supply voltage of 5 volts coming IN the USB socket. Hopefully that will allow it to turn on in camera mode again.
Fuji Zoom Error Message
Hello
Use
Firstly ,
Try holding the
Look at the lens ,
Try gently
Another
Try hitting your
your hand.
center for a evaluation to see if it would cost more to repair than to
replace the camera.
Hope
found this helpful.
Regards
Andrea
Zoom error on finepix J50
Hello
Use
Firstly ,
Try holding the
Look at the lens ,
Try gently
Another
Try hitting your
your hand.
replace the camera.
Hope
the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Zoom error appearing cannot use camera
Hello
Use
Firstly ,
Try holding the
Look at the lens ,
Try gently
Another
Try hitting your
your hand.
replace the camera.
Hope
Regards
Andrea
