20 Most Recent Samsung SL310W Digital Camera Questions & Answers
Here is what the Samsung websites says:
MMCplus(up to 2GB guaranteed 4bit 20MHz);
SD (up to 4GB guaranteed);
SDHC (up to 8GB guaranteed);
So it is OK to use a 4GB SDHC memory card in your samsung sl310w.
Hope this helps.
Samsung SL310W... | Answered on Oct 11, 2019
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Samsung SL310W... | Answered on Dec 02, 2012
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101';
Samsung SL310W... | Answered on Aug 27, 2011
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Samsung SL310W... | Answered on Jul 28, 2011
Not really....you could use a separate card reader. It's a much better way to download. typrice_160.jpg
Samsung SL310W... | Answered on Apr 03, 2011
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Samsung SL310W... | Answered on Mar 19, 2011
Read page 84 through 90 of the SL310W user manual.
Samsung SL310W... | Answered on Dec 30, 2010
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Samsung SL310W... | Answered on Apr 17, 2010
sorry but once you format your camera it completely erases everything to make room. there is nothing you can do.
Use a card reader instead.
Samsung SL310W... | Answered on Nov 23, 2009
Take the card to a store that has a Kodak picture maker kiosk (like Walmart). Your pictures should show up and you can print them or even make a cd. After you do that, format the card in the camera before using it again.
Samsung SL310W... | Answered on Sep 17, 2009
maybe the memory card is bad?try changing it with a diffrent one!!!
Samsung SL310W... | Answered on Sep 07, 2009
There could be many different problems with this camera.
The batteries could be defective.
The camera itself could be defective.
The lens may be jammed.
I'm not there so I can't say exactly what is wrong. If possible, try to email Samsung and they will get back to you in at least 2 business days.
Samsung SL310W... | Answered on Aug 11, 2009
low battery power, replace batteries
Samsung SL310W... | Answered on Aug 05, 2009
hi
i know its sounds odd but yes the charge on the batteries (Voltage/Amps) is falling short for the camera to start as it takes more power to run the camera than to just preview your pictures
one suggestion i can give here is
(this could be potentially hezardous so tread caution)
if you have rechargale batts then try electro jump to them take any source which is roughly 2-3times the voltage of the batteries (eg: if the batt voltage is 1.25 volts take a 3-5volts source) and connect the +ve wire to the +ve and -ve wire to the -ve of the battery and hold for 10 to 15 secs and then immediatly place it for charging and let them fill charge and use them till the batteries are completely drained
repeat this cycle for 2 -3 times and batteries will come back to life
be careful to connect the wires correctly else they might destroy the batts also not to hold for more than 10-15 secs
cheers
pls rate if this was any help
Samsung SL310W... | Answered on Jul 06, 2009
take out the battery then put it in, turn on again, reset the camera.
Samsung SL310W... | Answered on Apr 08, 2009
Do you really need a driver?
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo management program.
Samsung SL... | Answered on Mar 26, 2014
Samsung SL310W Digital Camera Logo
20 questions posted
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
View Most Popular
SL Samsung
  • SL Samsung
Most Popular Question
need disc
  • Cameras
