20 Most Recent
Philips 50PL9126D/37B 50" DLP TV Questions & Answers
Why does my philips 50pl9126d/37 flickers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
9/1/2014 4:51:45 PM •
Philips...
Answered
on Sep 01, 2014
My 50 inch Phillips tv model #50PL9220D/37 wont
Hello more than likely the lamp has gone bad. On that set you have to remove the back cover to check the lamp to see if it has broken. the picture gives you an idea and some instructions on how to change it. tks
11/8/2013 4:03:59 AM •
Philips...
Answered
on Nov 08, 2013
I have a phillips tv that is about two years old
Being that your TV is only two years old,it is very possible that you may have one or more of the following,VGA,SVIDEO or HDMI..If you have one of the following you can connect to your computer(HDMI IS YOUR BEST OPTION IF AVAILABLE)
8/2/2013 6:15:43 PM •
Philips...
Answered
on Aug 02, 2013
I have a Phillips 50pl9126d/37
I currently have this problem also. However my TV is blinking 6 times fast and then 5 times slowly. I was told by a TV repairman that it was in fact the bulb or lamp. I plan to replace it, soon, I will keep you posted hopfully it works.
4/19/2013 10:15:21 PM •
Philips...
Answered
on Apr 19, 2013
