20 Most Recent Dell OptiPlex 330 Desktop Desktop Computer Questions & Answers
The first thing to check would be the CMOS to see if there is a setting for "case intrusion" or something to that effect. Some computers have sensor that goes off the computer's side panel is opened. I believe this can be disabled in the CMOS and/or it's just a wire connected to the motherboard that can be disconnected.
It could also be an important fan, like the CPU fan, isn't spinning fast enough which may or may not lead to an over-heated CPU.
Also check to be sure all the memory sticks are firmly seated.
If it doesn't look like any of those it could always the the power supply. See if you can borrow one for a little while for testing purposes just to see if it works.
If none of those pan out I would say call Dell support and see what they say.
Dell OptiPlex... | Answered on Apr 09, 2016
Try to clean the RAM and place it again in the motherboard.
Dell OptiPlex... | Answered on Mar 07, 2016
The bip-bip sound means that a necessary input/output device is missing or not working. Go to dell.com/support enter your service tag number download the manual (LINK included) if you have questions of how to search Dell Fourms. Please rate me mysleuth
http://support.dell.com/support/topics/global.aspx/support/product_support/product_support_central?~ck=ln&c=us&cs=19&l=en&lnki=0&s=dhs
Dell OptiPlex... | Answered on Apr 13, 2015
It could be your power supply. Does it power up and load O/S?
Dell OptiPlex... | Answered on Oct 19, 2014
Maybe you have a CD inserted or a USB flash memory attached to your PC disconnect it and try again.
Dell OptiPlex... | Answered on Oct 16, 2014
Either your Operating OS is bad or your hard drive.
Dell OptiPlex... | Answered on Oct 09, 2014
It could be one of two things, either your monitor is bad or the video card is bad. Try taken connecting your monitor to a different computer. If the monitor works then it the video card. You could just purchase a new video card and put in and it should work
Dell OptiPlex... | Answered on Sep 17, 2014
You could try to connect a different, working, monitor first. Should this not work, then you can be fairly sure that your monitor is good, but the problem lies either with your motherboard or just the integrated video circuitry on it. That being said, there's usually an option of installing an auxiliary video card on the motherboard expansion slots - preferably an AGP or PCI-X16 graphics card. Should you care to provide me the service code number for the tower, I can check with Dell to see which type card can be installed on this motherboard. Thanks!
If you have multiple IDE drives, try switching the data cables on the back of them.
Dell OptiPlex... | Answered on Jul 23, 2014
The pattern of the blinking can tell you a lot. if you can get the pattern and then reference the following site it can tell you the cause and some steps to remedy the situation.
Support Article This is a Dell Article that explains the various Blink Codes it covers the entire OptiPlex line, including all the changes that were made through the years.
Another option would be to print out the relevant portion of that page and keep it for future reference as well.
Dell OptiPlex... | Answered on Jun 18, 2014
So what's you question?
Dell OptiPlex... | Answered on May 06, 2014
Bluetooth is line of site so nothing can interfere with the connection...also other electronics can interfere with the signal.
Have you activated pairing sequence?
Dell OptiPlex... | Answered on Jan 17, 2014
Any floppy disks or USB Drives attached to the computer?
What is the boot Sequence as found in the BIOS?
More details of any troubleshooting that you have done would be helpful.
Dell OptiPlex... | Answered on Jan 08, 2014
Have you tried changing the battery?
Dell OptiPlex... | Answered on Dec 12, 2013
You need to Purchase some Amplified PC speakers as a lot of computers come without Built in Speakers
Dell OptiPlex... | Answered on Dec 05, 2013
Dell OptiPlex 330 Desktop Desktop Computer  Logo
201 questions posted
Ekse
Clive
Clive
Alun Cox
View Most Popular
OptiPlex Dell
  • OptiPlex Dell
Most Popular Question
bluetooth enable
  • Computers & Internet
