20 Most Recent Kyocera FS-1118MFP Laser Printer Questions & Answers
In some cases you can reset the C 6000 - when is a false error.
try this:
1. Go to Menu/System and browse till you see
"Service".
press and hold: # START ENTER
The "Service" will go away and browse to "Maintenance".
2. Press ENTER to go in maintenace mode - the display change to Maintenance mode.
3. browse to 0163 and press ENTER - reset fuser
4. pick EXECUTE and press ENTER
5. turn the copier OFF, wait 20 seconds and power up the machine.
If C 6000 goes away it was a false error if NO ...try again and if the C6000 persist means the thermal fuse it is blown so you have to replace the fuse = call for service.
Kyocera... | Answered on Apr 10, 2019
UNLOCK THE SCANNER LOCK SWITCH ON THE PRINTER WORKING.
Kyocera... | Answered on Mar 29, 2018
Good afternoon,
Please can someone tell me what is the error C4600 printer kyocera TASKalfa 2551ci?
How can I solve it?
Kyocera... | Answered on Nov 17, 2017
There is a orange/yellow scanner lock at the back of the machine. You need to pull it towards you to unlock it.
Kyocera... | Answered on Nov 10, 2017
make sure the main charge cleaner is in home position
Kyocera... | Answered on May 04, 2017
check to see if all the lights are turning on as it tries to scan (do a scan with the lid up and nothing on the glass.
Possiby need to rplace the drum in the printer.
Kyocera... | Answered on Sep 06, 2016
I don't know that machine but generically, the description suggests a faulty drum or fuser unit...
How many prints or copies since either or both were changed, please?
Kyocera... | Answered on Sep 02, 2016
If you wish to get some details; check the site linked here. Pull up older posts..
http://electro-medical.blogspot.com/
Kyocera... | Answered on Jun 19, 2016
Defective power supply board. or Defective engine board
Kyocera... | Answered on Mar 31, 2016
no it can't however it should have a 10/100Base-TX ethernet port. You should be able to plug it into a Wireless Router and be able to access it via an ethernet ip network. However you would have to set the laser fs-1118mfp printer to an appropiate IP address and subnet mask and set the router to issue DCHP to Ip addresses outside the printer range of IP addresses. So for example 192.168.0.1 router 192.168.0.2 could be assigned to printer and DHCP leases assigned to 192.168.0.10 - 192.168.0.254 using a subnet mask of 255.255.255.0 for all the ip addresses. The router could communicate with laptops via wireless but each laptop would need the laptop operating system driver for the printer added and the ip address would be 192.168.0.2 for the printer. it could also be done on 10.0.0.whatever 10.0.0.1 router 10.0.0.2 printer 10.0.0.10 -10.0.0.254 DHCP server leases. If you have a ethernet network already you could just add a wireless access point to the network .
Kyocera... | Answered on Oct 09, 2015
Press the system menu/counter key,Select Service setting using the up/down cursor keys.While pressing the start key and the # key, press the enter key.then select 163 Resetting the fusing problem data Description Resets the detection of a service call code indicating a problem in the fusing section. When a service call concerning the fusing section occurs, turn the power switch off and open the front cover. Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode. Purpose To prevent accidents due to an abnormally high fusing temperature. Method 1. Press the enter key. A selection item appears. 2. Select Execute using the up/down cursor keys. 3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020, C6050, and C6400 are reset.) Completion Press the back key. The indication for selecting a maintenance item No. appears.
Kyocera... | Answered on Jun 28, 2015
try unpluging it(the power and the usb), count to 15 and plug back in
Kyocera... | Answered on May 21, 2015
yyou have to be careful when doing this.
the waste toner is built in to the process unit (drum unit) and has a plug on the side.
remove the plug and tip it out.
Kyocera... | Answered on Dec 11, 2014
3101: SMTP Authentication error. Consult with Your network
administrator to verify that your Login Account, Name and
Login Paswrod required for SMTP Authentication are correct.
Kyocera... | Answered on Dec 05, 2014
You can vacuum out the waste toner by removing the panel on the left or right side of the drum unit (can't remember). there is no plug. messy but it works
Kyocera... | Answered on Sep 30, 2014
corrupt print data.
set the driver back to KPDL, make sure to uncheck the "allow data pass through" in the settings area, this makes a world of difference and ends up eliminating alot of print errors. It's been talked about in other threads on this site. I've talked to KM tech support about this setting and they don't really know what it is for
Kyocera... | Answered on Sep 28, 2014
Remove the fuser unit and check if the heater lamp, the thermostat and/or the thermistor are broken
Usually when we say toner cover, we mean the top cover, which is the cover we open to change the toner kit (catridge).
The error C-6000 refers to the fuser unit. You have to remove the fuser unit and check if the heater lamp and/or the thermistor and/or the thermostat are damaged.
Check if you have put the little pwb inproperly or, in worst case, you have loose it. This pwb is in the left side of the processor unit. You will see a black circle tape near the grey tape of the grid cleaner.
Kyocera... | Answered on Sep 23, 2014
Kyocera FS-1118MFP Laser Printer Logo
166 questions posted
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
FS Kyocera
  • FS Kyocera
Most Popular Question
unlock printer kyocera fs 1118mfp when
  • Office Equipment & Supplies
