20 Most Recent Riso RZ220 Duplicator Questions & Answers
I cant return the drum for my machine risograph
This meens your Riso's timing is out.Put your drum in home possition by rotating it untill it locked.Slide the drum back into the machine.If this doesnt help you will have to realign the machine to the home possition.
Switch the machine off.At the back of the drum there is a gear that have to align with the Main drive gear of the machine.Turn the main drive gear untill the guides of the gear matches the drum' gear.But remeber that gear doent move easely.
Try to slide the drum back again.
Be carefull not to cut yourself with the inner plates of the machine
12/20/2023 4:11:38 AM • Riso RZ220... • Answered on Dec 20, 2023
RZ200 error code A06 403
The error code "A06 403" on the RZ200 duplicator indicates a problem related to the master-making process. This error can occur due to various issues within the machine. Here are some steps you can try to proceed with resolving the error:
  1. Power Cycle the Machine: Turn off the RZ200 duplicator and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on again. This simple reset might clear the error if it was caused by a temporary glitch.
  2. Check for Obstructions: Inspect the machine's internal components, such as the master-making unit, ink cartridges, and paper feed, for any visible obstructions or jams. Clear any blockages carefully.
  3. Clean Internal Components: Dust and debris can sometimes cause errors in the duplicator. Clean the internal components, particularly the master-making unit, with a soft, lint-free cloth or a compressed air duster.
  4. Inspect Master-Making Unit: The "A06" error code often relates to the master-making process. Check the master-making unit for any signs of damage or misalignment. Ensure that the master roll is loaded correctly and that all components are properly seated.
  5. Check for Ink Issues: Inspect the ink cartridges to ensure they are installed correctly and have enough ink. Low ink levels or improperly installed cartridges can lead to errors.
  6. Update Firmware (if applicable): If there is a firmware update available for the RZ200 duplicator, install it. Firmware updates can sometimes resolve known issues and improve performance.
  7. Refer to the User Manual: Consult the user manual or the manufacturer's documentation for the RZ200 duplicator for specific troubleshooting steps related to the "A06 403" error code
8/6/2023 5:43:48 PM • Riso RZ220... • Answered on Aug 06, 2023
Error code A06-403 THE
Sometimes when people lift the machine, they don't use the handles, there is a plate underneath the paper tray that bend, bend it straight and all will be fine
7/3/2022 7:23:13 AM • Riso RZ220... • Answered on Jul 03, 2022
2answers
Code D-17-236
A D17 is incorrect master roll installed. This could be caused by a) it IS the incorrect master roll, or b) the RF tag that is inside the master roll has gone bad. Try a new one in the original packaging to help with diagnoses. Make sure they are RISO Z type master rolls specific for an RZ220.
11/12/2021 6:48:06 PM • Riso RZ220... • Answered on Nov 12, 2021
2answers
Set language riso rp3700 from
D?finir la langue du riso rp3700 du japonais vers fran?aise?
11/3/2020 6:32:55 PM • Riso RZ220... • Answered on Nov 03, 2020
2answers
A17-209 error message
A-17-209 is a cutter error meaning the cutter is not at home position when master material is in place. The cutter can be manually slide towards front of machine or another way is to rerolled master paper back on to its roll and close the clamp. This will cause the cutter, if operational, to re-home itself correctly. There are test codes to operate cutter to check it (480).
9/16/2020 9:42:36 PM • Riso RZ220... • Answered on Sep 16, 2020
4answers
P-98 ---5 Riso RZ 370EP Please help me. What's
Riso error code p98
2/26/2020 11:58:48 AM • Riso RZ220... • Answered on Feb 26, 2020
2answers
Error code d-04 then 560
have to go in a change because its not riso ink...
11/13/2019 11:17:27 PM • Riso RZ220... • Answered on Nov 13, 2019
Code:p-01-537
this is a very tricky problem on the main motor ther is a steel cap covering a strobe disk and a sensor the sensor is dirty or faulty to get to it you have to take out the main motor
10/31/2019 9:30:50 PM • Riso RZ220... • Answered on Oct 31, 2019
3answers
Error code a06-403
Error code a06-403
6/7/2019 8:37:17 PM • Riso RZ220... • Answered on Jun 07, 2019
We have problem in our
Clean the cartridge with alcohol, dry, put it back in .
5/23/2019 4:41:14 PM • Riso RZ220... • Answered on May 23, 2019
What is p-01-538 code means in rz 220ui machine?
P01-538 is Print drum is not locked during operation. ( Drum lock sensor: OFF ) Check the drum release handle has not been forced to the "squeezed" open position.
4/15/2019 11:03:32 PM • Riso RZ220... • Answered on Apr 15, 2019
P-24-539 ez220 error, solution needed please
Depending on the error code, below is the list of error codes with explanations http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Riso&model=RZ220
3/15/2019 6:52:44 AM • Riso RZ220... • Answered on Mar 15, 2019
6answers
What does the error code E 01 stand for?risograph 4050
If its CR or TR, E-01 is main motor lock. turn off machine and hold reset button in while you turn the machine on again. Make sure your master removal unit and master feed unit are closed corectly.
2/28/2019 12:10:06 PM • Riso RZ220... • Answered on Feb 28, 2019
3answers
Problema para Riso - Duplicadora
where can i find the Riso RZ Paper-feed-tray upper or lower safety switch
2/28/2019 11:39:57 AM • Riso RZ220... • Answered on Feb 28, 2019
Error code t17-020
111998
1/11/2019 10:31:19 AM • Riso RZ220... • Answered on Jan 11, 2019
Riso gr 1700 e01 error
Riso has the answer on the back page of the manual
8/18/2018 3:40:22 PM • Riso RZ220... • Answered on Aug 18, 2018
0answers
We AEBO is professional manufacturer of compatible
How could your ink work in a Riso RZ220?
1/23/2018 11:09:54 AM • Riso RZ220... • Answered on Jan 23, 2018
487 questions posted
Top Riso Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Riso Office Equipment & Supplies
Most Popular Question
p 98 5 riso rz 370ep please help me
  • Office Equipment & Supplies
