20 Most Recent Gestetner DSM 651 Copier Questions & Answers
0answers
Mp5000 sc672
Be the first to answer 11/15/2013 6:55:06 AM • Gestetner DSM... • Posted on Nov 15, 2013Be the first to answer
2answers
Error code sc542 any ideas how to fix
Hi
Thanks for using FixYa. This error mostly occurs due to power outage. This error means that the fuser temperature and hot roller temperatures have warm up. After occurring of this error the printer will not work until your clear this error code.
To clear this error code follows this step by step procedure---
  • To Enter in Service Mode hold down the Online + Escape keys simultaneously and then turn on the printer.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arrow to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
This will resolve the issue by clearing the error code.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
8/13/2012 2:15:10 PM • Gestetner DSM... • Answered on Aug 13, 2012
Code SC124 means what
scanner home position error
7/30/2011 11:59:50 PM • Gestetner DSM... • Answered on Jul 30, 2011
I have a Gestetner DSm651sp
Most likely the toner dispenser is blocked. Its not getting the ink into the system. Did you shake the bottle well to be sure its not packed inside the bottle?
6/4/2011 1:05:58 AM • Gestetner DSM... • Answered on Jun 04, 2011
At first when machine get
This code is related to a bad communications between the controller and the operation panel.
Could have the following causes:
- Controller installed incorrectly
- Operation panel harness disconnected or defective.
- Controller board defective.
(also check the jumper on the MBU fax unit. It must be set at the ON position)
I give this answer for the SC672 assuming that you know why you remove the NVram...
5/18/2011 7:55:28 PM • Gestetner DSM... • Answered on May 18, 2011
Has a sc551 my printer
Web end detected 5 times within500 ms and web motor continues torotate 40 s. If web end is detectedfor another 400 ms, then the SC is logged that mean Fusing Web End defective
4/21/2011 5:43:43 PM • Gestetner DSM... • Answered on Apr 21, 2011
My Gestetner 4532 is not printing a code SC
That is a bad reading temperature of the Fuser Unit.
I will give same steps to unlock it.
Press yellow key
On the key pad press 1-0-7
Old the red key at least 3 sec
Press copy sp
Exit all the way out
Turn the machine Off / On.
This should be good. If doesn't work you have to call a technician to change some parts of the Fuser Unit like Hot Roller and thermistors.
Hope you understand.
3/2/2011 11:33:10 PM • Gestetner DSM... • Answered on Mar 02, 2011
I have a sc276 code
try this press the yellow clear button then 107 then hold down the stop button ..the screen will change and say copier sp enter then turn off the machine wait 5secs and turn on again..
7/19/2010 10:51:00 AM • Gestetner DSM... • Answered on Jul 19, 2010
Where can I purchase a fuser unit for DSm651sp?
user unit for your Gestetner DSm651sp can be purchase on your local dealer. What's your location/Country?
4/25/2010 7:53:52 AM • Gestetner DSM... • Answered on Apr 25, 2010
2answers
Document Server Not Holding Document
Hello sir; The answer for you is NO, you better save in CPU.
10/20/2009 3:42:35 AM • Gestetner DSM... • Answered on Oct 20, 2009
Message derreur cs 541 sur photocopieur RICOH Aficio 1035
sc 541 = Fusing thermistor open
5/7/2009 9:36:53 AM • Gestetner DSM... • Answered on May 07, 2009
Sc541
tRY REPLACING THE THERMISTER WHICH IS NEAR MIDLE.
Mohan
10/25/2008 2:49:22 PM • Gestetner DSM... • Answered on Oct 25, 2008
Error SC 541
Try this... Press the Yellow reset botton then the number "1" then "0" then "8", don't hold them down, just push each botton once. Then hold down the "Stop/Clear" botton till the display changes to service mode, then turn the main Power Switch OFF then back On and see if it warm up.... If it dose not warm up you may have a problem with the fixing unit.... Good Luck
9/20/2008 3:15:59 AM • Gestetner DSM... • Answered on Sep 20, 2008
Dsm651sp
Repalce the pick up rollers,paper feed rollers, seperation rollers of the trays which gives the pper jam
10/22/2007 12:34:45 PM • Gestetner DSM... • Answered on Oct 22, 2007
2answers
Ihave Gestetner 5327 an having
Check out the website www.arico1.com. They do repair on duplicator machine drums.
10/10/2021 2:53:28 PM • Gestetner Office... • Answered on Oct 10, 2021
How would I identify faulty fault sensors in gestetner MP2501L copier and replace them?
You can't. As I said you need the service engineer with the laptop. These Office Machines are NOT consumer serviceable. They hook up the laptop with the Ricoh software and it interrogates the computer, the mainboard and everything on it. The error message you get is from the brains inside it..Original question and answerhttps://www.fixya.com/support/t29802178-am_posting_again_stripped_off_gestetner..
1/15/2021 4:04:21 AM • Gestetner Office... • Answered on Jan 15, 2021
Am posting again. I stripped off gestetner MP2501L 8 times due to problem ' see instructions on right side to solve' but same. No paper inside. What is the actual problem.
Hello Christopher Are you in the Philippines? I notice that your copier has changed from Ricoh to Gestetner? We are a North American website. This is a commercial office machine, and from my experience of them is that on the right side you will see on the inside, a list of instructions for where to check for obstructions. It seems you have already done this 8 times! Frustrating! Try this; Open the right side cover, unlatch all the bits at that side. Open the straight pass door on the left side. remove ALL the paper drawers. Get a powerful flashlight, look in all the spaces you have just created, especially at the edges of drawers and paper pathways. You are looking for a tiny piece of paper that one of your employees carelessly left behind after a paper jam.The one I found was right at the back of the straight pass door. When a sensor is covered, it creates that message. If that fails, Ricoh will have to come and attach their Laptop scan software to it which will tell which sensor is obstructed or has failed.
1/14/2021 4:54:33 PM • Gestetner Office... • Answered on Jan 14, 2021
Gestetner DX2430 error code E-00
Clamper error The MPU cannot detect the clamper position sensor signal ( open or closed) within 3.0 seconds after the clamper
12/2/2019 1:38:38 PM • Gestetner Office... • Answered on Dec 02, 2019
Gestetner DSM 651 Copier Logo
23 questions posted
Top Gestetner Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
ZJ Limited
ZJ Limited
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Gestetner Office Equipment & Supplies
Most Popular Question
gestetner 4532 not printing code sc
  • Office Equipment & Supplies
