20 Most Recent
Gestetner DSm635sp Digital Imaging System Questions & Answers
Where I can download drivers
Hello!
Gestetner is made by Ricoh. They only change the name. The cross reference for your model is Aficio 2045e.
You can download from the
www.ricoh-support.com the driver of Aficio 2045e and your done.
Hope this helps you.
See you!
1/26/2015 3:57:35 PM •
Gestetner...
Answered
on Jan 26, 2015
Faxing with Gestetner DSm 635 sp Copier
There is a fax module that you can purchase to be able to fax from the copier. If it is already installed, you will see two phone jacks on the rear side of the machine. One will be labeled "Line" and one will be labeled "Tel" -- if you plug a phone cord from the jack in the wall to the jack labeled "Line," your copier is all ready to fax.
On the operation panel, there should be a button on the left labeled "Fax" under the buttons labeled "Copier" and "Document Server" -- press that button to get to the fax screen.
Hope that helps!
7/18/2010 6:12:42 PM •
Gestetner...
Answered
on Jul 18, 2010
How would I identify faulty fault sensors in gestetner MP2501L copier and replace them?
You can't. As I said you need the service engineer with the laptop. These Office Machines are NOT consumer serviceable. They hook up the laptop with the Ricoh software and it interrogates the computer, the mainboard and everything on it. The error message you get is from the brains inside it..Original question and answerhttps://www.fixya.com/support/t29802178-am_posting_again_stripped_off_gestetner..
Am posting again. I stripped off gestetner MP2501L 8 times due to problem ' see instructions on right side to solve' but same. No paper inside. What is the actual problem.
Hello Christopher
Are you in the Philippines? I notice that your copier has changed from Ricoh to Gestetner? We are a North American website.
This is a commercial office machine, and from my experience of them is that on the right side you will see on the inside, a list of instructions for where to check for obstructions. It seems you have already done this 8 times! Frustrating! Try this;
Open the right side cover, unlatch all the bits at that side.
Open the straight pass door on the left side.
remove ALL the paper drawers.
Get a powerful flashlight, look in all the spaces you have just created, especially at the edges of drawers and paper pathways. You are looking for a tiny piece of paper that one of your employees carelessly left behind after a paper jam.The one I found was right at the back of the straight pass door. When a sensor is covered, it creates that message.
If that fails, Ricoh will have to come and attach their Laptop scan software to it which will tell which sensor is obstructed or has failed.
Sc 569 for ricoh mp 5500
sc 569 is the pressure roller contact sensor error Troubleshooting Procedures: 1. Check or replace the harness of the pressure roller contact sensor. 2. Replace the pressure roller contact sensor. 3. Replace the pressure roller contact motor
SC 569 Error code in MP 5500
