20 Most Recent
Gestetner DSc224 Copier Questions & Answers
Show drum unit
Impossible to clean anything in a picture. You need to have the actual unit :)
DSC224 printer displays low on fuser oil
There is a sensor that need to be cleaned if the code will not clear. I believe there is a black float that is part of the fuser bottle. If you swing out the oil bottle and look where the float would be... There is a sensor, clean the sensor and make sure it is plugged in correctly... Good Luck
We want install cd
here;s the download link
http://www.ricoh-support.com/enduser/gestetner/advsearchresult.asp?type=download&ProdName=Multi+Functional+Products
Dsc224 ploblem sc142
Error Detection White Balance
The White Balance can not be resolved • glass or optical section
within the target at the Spotted
automatic gain control. • Card SBU defective
• Map BICU defective
• Exposure lamp defective
• Cruise the lamp defective
Waste Bottle 2 full
There are two tanks on toner cete machine. One down, one in the middle. This is the one that must be emptied
