20 Most Recent
Siemens WFXD5200UC Front Load Washer Questions & Answers
Started filling, made a loud noise, stopped
The washer drain the water if you put on spin. all electronically controlled washer won't unlock the door and or spin if there's water inside the water has to be drained out first.If the basket didn't move(no motor movement) and it finished the cycle, POSSIBLE problem is the motor control board.
Motor Control Board 00436461
11/23/2017 3:57:24 AM •
Siemens...
Answered
on Nov 23, 2017
Washing machine
f63 shoes on machine
siemens e 12 46 is the machine only 4 months old is there anything i can do befor i call an engnieree
7/11/2016 9:46:07 PM •
Siemens...
Answered
on Jul 11, 2016
Clinking sound in a Siemens WFXD5200UC/01 front loading washer
I would suggest that a small thin metal item has got into the outer drum unit. This is the space between the internal spinning drum and the outer casing. This can sometimes happen by the object passing between the rubber door seal and the drum. Not easy to get out, however if it is small enough it may eventually find its way into the pump filter trap. There is a small round cover plate at the bottom right hand side of the machine. Behind the cover is the filter trap, open it up (when machine empty) and check for the object every so often. To open the filter turn the plug cover about a third anticlockwise and it should release. Pull gentle on the plug to remove from the machine.
2/14/2016 11:03:58 PM •
Siemens...
Answered
on Feb 14, 2016
Error code F 17 on model E 12-46
Most likely not getting water from supply line or if buzzing noise under top control valve issue according to another post. hope this helps. Gene
6/16/2014 8:31:58 PM •
Siemens...
Answered
on Jun 16, 2014
