20 Most Recent Gestetner DSm615 Digital Imaging System Questions & Answers
2answers
Machine shows a service code of sc 928
The SC - 928 is a Memory error problem.
The machine detects a discrepancy in
the write/read data during its write/read
test (done at power off/on and at
recovery from low power or night/off
mode). To try to reset this code -- Turn the MAIN power switch off, wait about 30 secs. then turn switch back On.
Possible causes:
• Memory defective
• BICU defective
• Poor connection between BICU and
memory
The cheapest repair would be to replace the memory. It is rare the the connections came apart unless some one was in the back of the machine for some reason.
5/20/2017 6:21:25 AM • Gestetner DSm615... • Answered on May 20, 2017
Describe your error code SC928 Problem
when i on machine appear sc 928
5/17/2017 8:14:40 AM • Gestetner DSm615... • Answered on May 17, 2017
2answers
What is the repair code
please tell me what is your code in this machine -thanks
7/27/2014 10:38:34 AM • Gestetner DSm615... • Answered on Jul 27, 2014
I have a nashuatec dsm615 with a error code
Resetting a machine may cause damage on the costly internal parts inside. The cpu has an ability to detect error codes and what type of error it is on the machine but resetting it will only "FORGET" what has been currently detected but still the problem exists on the machine even it is successfully done. If you will continously use the machine that has been resetted, therefore a possible simple problem can cost serious damage. Just a reminder before resetting. Thanks for using Fixya.
7/27/2014 10:34:28 AM • Gestetner DSm615... • Answered on Jul 27, 2014
2answers
Gestetner DSm615 giving error SC:552,How do i clear it
Are you sure of the code? I don't have the exact manual for that, machine but the number seems strange. "5xx" errors are usually related to the fuser, so could be a bad lamp, thermistor, or fuse. see note to reset (if there is not a problem) as follows:
There are 2 levels of service call conditions.
Level Definition Reset Procedure
"A"
To prevent the machine from being
damaged, the SC can only be reset by a
service representative.
The copier cannot be operated at all.
Enter SP 5-810 (SC code reset) and
select “1”. Then hold down the Original
type key and the OK or ! key at the
same time (this does not require the
main switch to be turned off and on).
7/20/2014 9:59:34 AM • Gestetner DSm615... • Answered on Jul 20, 2014
My machine shows sc 500
tray lift sensor defective . please try and check the sensor positioning ans correct it
6/18/2014 3:04:59 PM • Gestetner DSm615... • Answered on Jun 18, 2014
0answers
Dsm615
Be the first to answer 1/17/2014 10:28:44 AM • Gestetner DSm615... • Posted on Jan 17, 2014Be the first to answer
Code ricoh service
Reset the mechanical total counter.
1/12/2014 11:41:29 AM • Gestetner DSm615... • Answered on Jan 12, 2014
544 code error machine
Fusing overheat error.Verify the fuser unit components and the connections.If OK try to reset : press the yellow key 107 Stopred key enter in SP mode open the front door and turn OFF the copier.Wait 10 seconds and turn ON.
1/12/2014 11:38:42 AM • Gestetner DSm615... • Answered on Jan 12, 2014
Ce trebui sa fac;pentru ca nu-mi iese foaia copiata,ramane armonica in interior
Verificati unitatea de fixare a imaginii,(partea de cuptor)verificati in ea ghearele de desprindere a hartiei de pe rola superioara,eventual daca rola este murdara curatati cu o carpa inmuiata in diluant sau nitrosolv.Verificati si rola inferiara si rolele de stergere/curatare a rolei inferioare.Pentru asta trebuie sa demontati unitatea de fixare.Daca mai aveti probleme contactati-ma.
2/26/2013 7:48:24 PM • Gestetner DSm615... • Answered on Feb 26, 2013
2answers
Machine display an error code sc 500
YOU MUST RESET machin by: press clear mode key(yellow)---enter 107 by keyboard----press clear/stop key (red) for4 seconds--- turn off machin and on
9/17/2012 5:15:49 PM • Gestetner DSm615... • Answered on Sep 17, 2012
Service manuals
You have no factory service manuals due to copyrighting.
7/25/2012 4:54:36 PM • Gestetner DSm615... • Answered on Jul 25, 2012
My copies came out with
Start simple, clean the platen glass and **** glass with an alcohol wipe or a small amount of windex. If line still appears it could be the process or the fusing units. Hope this helps
8/6/2011 3:52:25 PM • Gestetner DSm615... • Answered on Aug 06, 2011
2answers
Error SC541 ON NRG MP 1600L
First try entering into SP mode by pressing:
Clear button>1 0 7> and press and hold the Stop button for 3 secs. Then switch off and on the copier.
If SC 541 code is still there, check the following in the fuser unit:
  • Fusing thermistors defective or out of position
  • Thermostats open circuit
  • Power supply board defective
  • Loose connectors of Fuser unit.
Good luck and please rate me, thanks.
7/3/2011 3:40:32 PM • Gestetner DSm615... • Answered on Jul 03, 2011
I have a problem with
Ok! I found your model.
This code refers to a Main Motor Locked.
Almost certainly is an overload.
Try to change the Fotoconductor Unit.
There are been reported several problems with this machines. And the main reason is a defect in the Fotoconductor Unit.
If you still have a old one or eventually a new one try to change it and your problem is solved.
See you.
4/27/2011 8:04:32 PM • Gestetner DSm615... • Answered on Apr 27, 2011
The paper comes out wrinkled
this problem always happened change paper kind if yo use 60g change to 70g and use good paper
4/8/2011 8:35:09 AM • Gestetner DSm615... • Answered on Apr 08, 2011
Thank you for this opportunity.
i think your problem with drum module please replace it and cleane the opticus -thanks
3/12/2011 1:32:30 PM • Gestetner DSm615... • Answered on Mar 12, 2011
48 questions posted
Top Gestetner Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
ZJ Limited
ZJ Limited
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Gestetner Office Equipment & Supplies
Most Popular Question
code ricoh service
  • Office Equipment & Supplies
