20 Most Recent
Cutler Hammer Cutler-Hammer No.BR48L125RP 125A Out Load Center Questions & Answers
Need wiring info for cutler
Probably easier and about the same price to just buy a shunt trip main breaker. IIRC, code usually requires that anyway.
As far as the c25dnd330, it's just a regular 3 pole contactor, each pole is good for 30 amps. The three poles are L1,2,&3>>>T1,2,&3. The other two contacts are the control coil. I believe your model is 120 volt (most are)....the voltage should be stamped somewhere near the contacts.
After hitting the test button
I believe you are referring to a GFCI receptacle. The Ground Fault Circuit Interrupt is an inline circuit breaker that reacts so quickly it can save lives that may be at risk of electrocution.
In hitting the test button, you have simulated one of those scenarios. The GFCI acted as it should by cutting power.
There should be another button marked 'RESET'. Press it to restore the normal functionality.
If I guessed wrong as to the problem you were trying to convey, please comment back with more detail.
Thanks for using FixYa
Best regards
Mike
Kango 950 motor runs but hammer only engages sometimes
This is an indication that the hammer needs service. When you take the barrel off you will see the striker. There is a piston inside the striker, when the rubber rings on the piston wear out you have the problem you describe. time to replace the motor brushes clean and regressed, make sure to use the correct grease, Check the backlash on ring and pinions. Don't put too much grease on the piston or it will stick and not strike. Good luck I forgot to ask which version. This is for the uk atlas coco, silver with blue or red handle
5/29/2022 2:06:56 AM •
Hammering
Answered
on May 29, 2022
Where can I get a set of brushes for a kango 950X
Unfortunately, you won't find them - Kango was a great hammer, but the company has been gone for many years and there are no parts available.
I would find a local repair shop that may have a different brand brush that is the same or bigger dimensions - by using a piece of 220 grit sandpaper on a hard, flat surface - you can sand them down to the proper size.
It will get you out of a bind
3/3/2021 2:37:44 PM •
Hammering
Answered
on Mar 03, 2021
Which type of oil for rok demolition hammer thank you
If an oil sight glass is in the modelrange of the brand ROK Rottela 40 , but if no sight glass is used in the model then often is to use special Grease lubrication. or only an special volume of oil and most used of them are zinc-free hydraulic based and included in the manual instructions of a maintenance set (service kit)wear parts set.
5/29/2019 9:53:04 AM •
Hammering
Answered
on May 29, 2019
Switch for kango 950 S
- The total condition of the seal anvil piston and striker are very important for the total condition of impact when spending a service kit (maintenance) when there is leakage at the front part everything will be hot inside and the rings will harden again quickly.
kango 900 950 round switch housing
8/16/2018 7:56:48 PM •
Hammering
Answered
on Aug 16, 2018
